				What is this size???
				Posted: Fri Mar 05, 2004 11:13 am
				by GT_03
				I was curious what this size meant. 5 Lug 5-4 1/2 bolt pattern. Thanks alot.
				Re: What is this size??? (GT_03)
				Posted: Fri Mar 05, 2004 11:40 am
				by MadBill
				Well, with that dash after the 5, it  should mean machined for 5 wheel studs and with a double or slotted pattern fitting both a 5" and a 4-1/2" bolt circle diameter. (The Vibe is 100 mm, or 3.94") It might however just be a doubling up on the 5 bolt pattern info and indicate a 4-1/2" bolt circle
				Re: What is this size??? (MadBill)
				Posted: Fri Mar 05, 2004 3:46 pm
				by redtrdmatrix
				5 on 4.5" = 5 on 114.3mm which will not work on our cars since we need a 5 on 100mm.
