Clutch Question
Posted: Fri Mar 05, 2004 5:29 am
by drummerdude
has anyone noticed that when you push in the clutch it squeaks? it started doing it yesterday and its really annoying if ur in traffic with no music on. any one ever heard of anything like this?
Re: Clutch Question (drummerdude)
Posted: Fri Mar 05, 2004 6:20 am
by Sub-Vibe-R
Mine did that twice up to now. I bring the car to the dealer and they lub the clutch axel shaft.
Re: Clutch Question (Sub-Vibe-R)
Posted: Fri Mar 05, 2004 7:33 am
by MadBill
Mine started to in the cold weather. If it returns now that it's warmer, I figure a shot of WD 40 should take care of it.
Re: Clutch Question (MadBill)
Posted: Fri Mar 05, 2004 11:04 am
by Kissfan79
Mine did it when it got really cold outside as well. I haven't heard it squeek when it is warm though.Jim
Posted: Fri Mar 05, 2004 1:08 pm
by DavidPIL
Hiya...Yeah, I notice a noise on occasion. Actually it was warmer today but very humid and it did it. Mine sounds like a wheeze. I'm thinking maybe it's allergic to humidity.Dave
Re: Clutch Question (DavidPIL)
Posted: Fri Mar 05, 2004 2:19 pm
by drummerdude
Quote, originally posted by DavidPIL »Yeah, I notice a noise on occasion. Actually it was warmer today but very humid and it did it. Mine sounds like a wheeze. I'm thinking maybe it's allergic to humidity.Thats exactly what mine did... its warm and humid. where would you put the wd40 bill? I have yet to do any clutch work. The squeak only heppens when you push the clutch in... when letting it out it doesn't do it.
Posted: Fri Mar 05, 2004 5:46 pm
by Kissfan79
Yup Yup.....same here.Jim
Posted: Fri Mar 05, 2004 8:40 pm
by MadBill
I'll be giving it a shot today, so will let you know, but I figure the squeak is in the pivot bearing. [although it was a record high by 4 degrees C./8 F. yesterday (18.2 C/65 F) here yesterday, so it may have faded on its own.]
Posted: Sat Mar 06, 2004 9:17 am
by MadBill
Update: killed my clutch squeak! However I was mistaken; it wasn't the brake pedal pivot; it was the rubber boot on the cowl that the pushrod passes through. I ended up using a Teflon spray on the pushrod (but I'm sure WD 40 or silicon would do) and just one little burst did the job. Now to see how long it lasts...
Posted: Sat Mar 06, 2004 9:39 am
by hman33
mine to, just noticed last week. it sqeaks when i push it in and when i let it out. only have 7,600 miles on it. when the weather gets better i'll have to try the wd-40 or the silicone spray.
