Wiper Blade Replacements
Posted: Tue Mar 02, 2004 1:37 pm
by NovaResource2
My original wiper blades are almost 2 years old and today I noticed the driver side blade is starting to split. So I call up a local Pontiac dealership for prices on insert replacements. Then I call a local Toyota dealership for their prices (both the Pontiac and Toyota dealerships are owned by the same person and are less than a mile from each other).Driver side front: Pontiac = 12.95; Toyota = 6.55Passenger side front: Pontiac 12.95; Toyota = 5.52Rear: Pontiac = 12.26; Toyota = 3.41Total for all 3: Pontiac = 38.16 + tax; Toyota = 15.48 + taxWhere do you think I bought them from? BTW, the Pontiac dealership only had the rear wiper in stock while the Toyota dealership had all 3.Another note, my original wiper blades have "TOYOTA" stamped on them.
Posted: Tue Mar 02, 2004 1:46 pm
by Jahntassa
Man..that toyota dealership is cheaper than getting them from Pep Boys! (I think)... It at least has to be less annoying than trying to replace that rear blade...
Re: Wiper Blade Replacements (NovaResource2)
Posted: Tue Mar 02, 2004 1:59 pm
by ArcsVibe
I really don't understand the Pontiac dealer trying to screw you with those prices??? I have done the same thing in the past as well, called a Pontiac dealer for a part then called Toyota...and Toyota ALWAYS qoutes me the lowest price.Good job Nova on getting the best price ( and I am sure the best service at Toyota! )
Re: Wiper Blade Replacements (ArcsVibe)
Posted: Tue Mar 02, 2004 9:43 pm
by ragingfish
More likely than not, the Pontiac dealer is more costly because GM has to buy the parts from Toyota...double markup.
Re: Wiper Blade Replacements (ragingfish)
Posted: Wed Mar 03, 2004 12:05 am
by Mavrik
GM always has higher prices... sadly I know I lose jobs in the shop because my parts department is priced us out of the market. Toyota prices would seem cheaper then Wal-Mart. GM has this high price with everything, not just Vibe parts. Wipers for a montana are like $25 canadian... each.
Re: Wiper Blade Replacements (Mavrik)
Posted: Wed Mar 03, 2004 1:25 am
by ArcsVibe
And then they wonder why dealerships close??
Posted: Wed Mar 03, 2004 1:38 am
by Mavrik
$24 for a Vibe oil filter? yeah ok sure... I talked them into selling it through our change package at cost so my oil change price did not go sky high...
Posted: Thu Mar 04, 2004 11:15 am
by NovaResource2
Quote, originally posted by ArcsVibe »Good job Nova on getting the best price ( and I am sure the best service at Toyota! )I didn't have the dealership install them, I just bought the parts from them. In a side note, the replacemet were just the rubber blades. You reuse the metal inserts from the originals.
Posted: Thu Aug 16, 2012 3:25 am
by knighttony13
Better get the Toyota wiper. Its cheaper and will surely fit your car. After buying my wiper blade refills for toyota i was excited to install it because i have been told that the quality is really excellent but then i realized that i am not yet familiarized on doing stuffs on my own. i even had to research online for some DIY steps. lol.
keep it up!
Posted: Thu Aug 16, 2012 9:10 am
by ehoff121
Anco wiper blades and refills from Wal-Mart are a good value.
I've used Toyota blades and refills in past, but it seems like they changed the "formula" at some point in the last couple of years and the last set I had didn't last very long.
The Anco blades were rated highly by Consumer Reports and they are cheap enough to change as often as needed.
Also, consider installing driver side blades that are an inch or two longer to decrease the size of the "triangle" in the middle.
Posted: Sun Sep 02, 2012 5:20 pm
by Mark
I like the Michelin Stealth blades, about $12 ea at Walmart. I replace them once a year, usually just before winter so later this month or in October, depending on the weather. Probably don't need to do it that often, but the Vibe is not garaged and the sun at 6000 feet takes a toll on them. And I'd rather know I have good ones than find out during a blizzard in December that they suck.
Posted: Tue Sep 04, 2012 10:07 am
by circuitsmith
There's lots of online vendors that sell Toyota parts at reasonable prices.
I order wiper blades, filters, drain plug washers to last a couple of years.
Here's a few I've used:
http://www.toyota-parts-dealer.com/factory.htm" onclick="window.open(this.href);return false;
http://www.trademotion.com/partlocator/ ... eid=214001" onclick="window.open(this.href);return false;
http://www.toyotaparts4u.com" onclick="window.open(this.href);return false;
