Which Magnaflow Cat to use?
Posted: Mon Mar 01, 2004 9:14 am
by Psychobroker
Which one of these Magnaflow Catalytic Converters should I use for Magaflow's cat-back and why?
Re: Which Magnaflow Cat to use? (Psychobroker)
Posted: Tue Mar 02, 2004 7:40 am
by Psychobroker
*post bump*Anyone have an idea of which one to use?
Posted: Thu Mar 04, 2004 8:36 am
by Psychobroker
*Another post bump*
Posted: Thu Mar 04, 2004 10:44 am
by Jahntassa
If you look at the descriptions, the only difference between the four is the pipe diameter. You just need to pick the one that fits the plumbing you've got.
Posted: Thu Mar 04, 2004 12:53 pm
by MYKIDSGT
arent we 2 1/4 in and out, I might be wrong.just trying to help.
Cat
Posted: Thu Mar 04, 2004 11:58 pm
by Psychobroker
Ahh ok, then should I try to match the stock piping before the cat, or the magnaflow cat-back?
Re: Cat (Psychobroker)
Posted: Wed Mar 10, 2004 6:51 am
by Psychobroker
*LAST BUMP*?So, 2.25" then?
Posted: Wed Mar 10, 2004 7:08 am
by savedbyzero
Check out Catco high-flow cats as well.
Re: Cat (savedbyzero)
Posted: Thu Mar 11, 2004 12:17 am
by Psychobroker
ugh, i just want to know what size I should order...I want to stick w/ Magnaflow since it matched my exhaust Also, I read somewhere that our Vibes have TWO cats? Does this mean I have to buy two??
Posted: Thu Mar 11, 2004 2:02 am
by savedbyzero
2.25" is the size you need. I believe that there is only 1 cat, and one resonator.
Posted: Thu Mar 11, 2004 3:52 am
by Psychobroker
ok, thanks saved! Any idea what gains, if any, I could expect from a high-flow cat?
Posted: Thu Mar 11, 2004 8:07 am
by dmitri
just jack it up and measure man. and no, its 1 cat
Re: Cat (dmitri)
Posted: Mon Mar 15, 2004 3:36 am
by Psychobroker
Easier said than done when, a) I don't have jack stands, b) nor ramps, c) nor a floor jack, d) very little free time.This is why I come to you guys for advice.
Posted: Mon Mar 15, 2004 8:25 am
by MadBill
Quote, originally posted by Psychobroker »Easier said than done when, a) I don't have jack stands, b) nor ramps, c) nor a floor jack, d) very little free time.This is why I come to you guys for advice.Free advice is often worth just what you pay for it, Psycho! A few points:o Saved and Dimtri are wrong! (sorry guys) On the base engine there are definitely TWO cats! (and I'm 95% sure it's ditto on the GT) One is right at the exit of the header and the other is a short distance downstream, followed by a resonator and finally the muffler. Take your Vibe to a friendly garage for an oil change and get them to let you take a brief walk under the hoist and check for yourself. o That said, it would be quite hard to change the first cat, as it is practically a part of the header. o Also, in many jurisidictions it is illegal to change out a functioning cat.o Lastly, before removing the factory part, you should seek some unbiased assurances that the replacement will actually flow better!
Re: Cat (MadBill)
Posted: Mon Mar 15, 2004 8:56 am
by Psychobroker
Thank you MadBill!! You are the MAN, as usual!
Posted: Tue Mar 23, 2004 3:03 pm
by cdFxer
I asked ptuning for more information about the model they list. Here is what they say:[ Dear Customer,Thank you for your inquiry.You can gain some hp with a high flow cat. Keep in mind that the cat isuniversal fit, so that muffler shop will have to weld the cat to yourexisting system.Please contact us if you have any further questions.Sincerely,Performance Tuninghttp://www.ptuning.com"Low Price Guarantee"
