Need this device!!!!
Posted: Sat Feb 28, 2004 9:19 am
by wicked1981
Well Has anyone purchased this or heard about this? I think it would be cool to have it.http://www.mirtworld.com/mirt-...t.asp
Re: Need this device!!!! (silverawd26)
Posted: Sat Feb 28, 2004 11:34 am
by Sub-Vibe-R
I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.
Re: Need this device!!!! (Sub-Vibe-R)
Posted: Sat Feb 28, 2004 12:23 pm
apparently they do work, and that is why they either are pushing or just passed a law to make them illegal for non-emergency vehicles in Maryland. if a lo of people had them it would make regulated traffic flow degrade into total chaos, and it's bad enough already.
Posted: Sat Feb 28, 2004 11:12 pm
by wicked1981
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly.I think these are meant for emergency vehicles so it might work just like the fire department in Quebec that you mention.
Re: Need this device!!!! (wicked1981)
Posted: Sun Feb 29, 2004 5:20 am
by Fialchar
Although I don't know anything about it, the cops here have a device to change red lights to green as well.
Re: Need this device!!!! (Fialchar)
Posted: Sun Feb 29, 2004 5:42 am
by NovaResource2
The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1
Re: Need this device!!!! (NovaResource2)
Posted: Sun Feb 29, 2004 5:59 am
by engine1
Quote, originally posted by NovaResource2 »The device is real but it is a felony for a private citizen to own one. Also, the device only works on signals designed to use them. It does not work on regular signals.More info: http://caranddriver.com/articl...ber=1 You are bang on! We have them installed on our trucks. We have four intersections that are set up to react to this system. Get caught using these on a private vehicle and expect very heavy fines!
Posted: Sun Feb 29, 2004 6:03 am
by engine1
Quote, originally posted by Sub-Vibe-R »I doubt this thing really works.Most (almost all) of light are running with programmable time and some with sensors (kind of magnet under the ground to detect metallic mass or simply movement sensors). I cannot see how this thing can tell a time to chage the light right away instead of at the end of his countdown.But, I know here, in Quebec city, the fire depatment implemented a new system to have the light turning green when the fire truck is coming. This system is very complex and worh with FM signaling and GPS. And all intersection have to be updated with the FM receptor to work properly. It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc..
Re: Need this device!!!! (engine1)
Posted: Sun Feb 29, 2004 10:48 am
by Sub-Vibe-R
Quote, originally posted by engine1 » It works on the strobe effect not a radio signal. The radio signal is not used because of the effects of weather, proximity of other signals etc.. The one in Quebec city really work with FM signal. They choose this way over the infra-red signal.It can have many way to do this, infra-red, FM, strobe effect....
Posted: Mon Mar 01, 2004 6:30 am
by engine1
I guess anything is possilble out there eh?? Jean-Paul
