				Would these fit????
				Posted: Fri Feb 27, 2004 11:44 pm
				by GT_03
				I found these on Ebay, and am considering getting them, but are they too wide???  I think the bolt pattern should be fine.
http://cgi.ebay.com/ebaymotors...%3AIT
				Re: Would these fit???? (GT_03)
				Posted: Sat Feb 28, 2004 1:57 am
				by MadBill
				The offset and width will be fine. I don't see the bolt pattern listed (which is 100 x 5 for the Vibe), but the models shown as covered match. The biggest issue is tires: First, 19" rubber costs a ton. Second, with anything close to a stock outside diameter, you will need dead smooth streets or pothole radar to keep from bending them, due to the short sidewall. Also, try checking out the appearance of this or a similar wheel as installed on your Vibe on something like the
http://www.tirerack site. Sometimes a 19 is just a tad too much.
				Re: Would these fit???? (MadBill)
				Posted: Sat Feb 28, 2004 4:52 am
				by GT_03
				Thanks alot, i think i might just get 18's and a 40 series tire.
