Fog light
Posted: Fri Sep 20, 2002 10:02 am
by Dan
I would like to know why there's no light on the dash that indicate that the fog light are on/off. Usually there's always a light that indicate that the light are on/off... It's not usefull when is dark outside (because you can see if the fog light are on/off) but during the day it's pretty annoying... you must check if you're fog light's switch is on or off.Another thing, do you thing that it's easy to place a small light that turn on when the fog light are on ?? Thanks[Modified by Dan, 9:02 PM 9/20/2002]
[Modified by Dan, 9:03 PM 9/20/2002]
Re: Fog light (Dan)
Posted: Fri Sep 20, 2002 12:21 pm
by NovaResource
I would like to know why there's no light on the dash that indicate that the delay wipers are on/off. Usually there's always a light that indicate that the delay wipers are on/off... It's not useful when it's raining hard outside (because you can see the wipers are going) but during light mist it's pretty annoying... you must check if your wiper delay switch is on or off.
[Modified by NovaResource, 11:10 AM 9/21/2002]
Re: Fog light (Dan)
Posted: Fri Sep 20, 2002 1:38 pm
by NSimkins
quote:I would like to know why there's no light on the dash that indicate that the fog light are on/off. Usually there's always a light that indicate that the light are on/off... I have personally never seen a vehicle that has this option. On some vehicles, the headlight knob has a little light built into the knob that indicates whether the fog lamps are on. This is a knob I have seen that is mounted on the dashboard however, not on the steering column, like the Vibe.quote:It's not usefull when is dark outside (because you can see if the fog light are on/off) but during the day it's pretty annoying... you must check if you're fog light's switch is on or off.If I may ask, what is wrong with just glancing down at the fog lamp switch to see if it is in the ON or OFF position?
Re: Fog light (NSimkins)
Posted: Fri Sep 20, 2002 10:58 pm
by Dan
quote:I have personally never seen a vehicle that has this option. On some vehicles, the headlight knob has a little light built into the knob that indicates whether the fog lamps are on. This is a knob I have seen that is mounted on the dashboard however, not on the steering column, like the VibeMy parent have a Mercury Mystic 98 that have fog lamps and they have a light that indicate that this switch is on/off . But is a knob that is mouted on the dashboard. (but the light is not into the knob..it's a seperate light (it is a light situate near the parking brake light ! )quote:If I may ask, what is wrong with just glancing down at the fog lamp switch to see if it is in the ON or OFF position?Nothing... I was just curious to know if someone has put a light to indicate that the fog lamps are on or off...I still love my vibe !!! It's a great car !
[Modified by Dan, 9:59 AM 9/21/2002]
Re: Fog light (Dan)
Posted: Fri Sep 20, 2002 11:00 pm
by rasermon
FYI: During the day your fog lamps will not function while your DRL are on.
Posted: Tue Oct 08, 2002 4:32 am
by Big_Red
Saturn, Saab, Toyota, Chrysler, Honda's...basically every car company has a way to show that the fog lights are on. I agree that they should have had some sort of indication that shows that the lights are on. Maybe in the next generation of Vibe (due out in 2006).
Re: Fog light (Salsa03)
Posted: Wed Oct 09, 2002 3:38 am
by Sub-Vibe-R
My 2001 Montana has cluster in the dask to indicate fog light are on.i think tihs is not very usefull cause I put on the fog light button when I bought my van and it stay on all the time since then.I will the same when I'll get my Vibe
