GTP motor in Vibe?????
Posted: Mon Feb 23, 2004 12:31 pm
by dcyco1
Has anyone ever thought of transplanting GTP motor in the Vibe. They already do this to Cavaliers so I am wondering if this could be done. I know it would be tight but if it fits, it could be made to work. I would think this would be a cheaper option in the long run compared to a turbo setup.Just wondering......
Re: GTP motor in Vibe????? (dcyco1)
Posted: Wed Feb 25, 2004 2:28 pm
by ALi3N
If you are refferring to the Grand Prix GTP, no. The GTP uses a Supercharged 3800 SFI V6 that takes up a lot of real estate under the hood. The Vibe barely has enough room for a supercharged 1ZZHE 1.8 L4 that is offered. I am sure with enough cutting and welding and tens of thousands of dollars, perhaps... but not worth the trouble IMO.
Re: GTP motor in Vibe????? (ALi3N)
Posted: Fri Feb 27, 2004 4:58 am
by bassvibes84
Well,I dunno. If you compare the two side by side, it could probably be done with a little fabrication. And a lot of computer work. However, the power gains may or may not outweigh the added weight of the bigger engine.
Re: GTP motor in Vibe????? (bassvibes84)
Posted: Sat Feb 28, 2004 3:15 pm
by Stang2Vibe
And the way that the weight is located will make the Vibe handle very different I would think. It would require suspension work as well, and still may never be quite right (without getting into major bucks anyway).
