alcohol cleaning
Posted: Sat Feb 21, 2004 1:39 am
by mrgrn
Will rubbing alcohol take off armarol?i am trying to get ready to do the badge overlays and door sills, and need some thing to clean all grease off?
Re: alcohol cleaning (mrgrn)
Posted: Sat Feb 21, 2004 1:49 am
can't hurt to try.if that doesn't work, give goo gone or un-do a try.
Posted: Sat Feb 21, 2004 9:39 am
by Stang2Vibe
Yeah, I'd use some kind of degreaser (like ragingfish listed or there are many others, you've probably already got something around the house that will work) and then use the rubbing alcohol. The alcohol alone will probably not cut through all the armor-all in one try.
Re: alcohol cleaning (Stang2Vibe)
Posted: Sun Feb 22, 2004 12:37 pm
by GrafxWerks
Rubbing alcohol really is you best bet as it will evaporate and not leave any additional residue behind. You start playing with degreasers and such and you'll end up with residue from it as well.- RyanGrafxWerks
Posted: Sun Feb 22, 2004 1:14 pm
by dsegundo
Alcohol will work. I'd make sure that you use a diluted version...about 1:1 with water. Also, Don't leave it on the car for long periods of time, it will eat your clear coat...I can guarantee you that.Desi
Posted: Sun Feb 22, 2004 4:36 pm
by Stang2Vibe
It would evaporate before it would eat the clearcoat. And when it evaporates, it too can leave residue behind, usually the residue of whatever it dissolved.
Re: (Stang2Vibe)
Posted: Mon Feb 23, 2004 7:07 am
by mrgrn
thanks guys
Re: (mrgrn)
Posted: Mon Feb 23, 2004 9:48 pm
by drunkenmaxx
ya know, they say dawn dish soap is used to get oil off of animals affected by a spill...
Re: (drunkenvibe)
Posted: Tue Feb 24, 2004 7:10 am
Dish soap will take the wax right off...don't use it unless you plan to wax right away...
