cigarette lighter
Posted: Sun Feb 15, 2004 4:31 am
by gogoputter
I don't smoke but I recently attempted to remove the cigarette lighter so I could plug in my cell and the entire cigarette lighter and assmbly came out about an inch but I could not separate the lighter from the receptacle. This is really odd but has anyone else had this problem? and....how does one get to this assembly to fix it. Any help is appreciated.thanks !!!
Re: cigarette lighter (gogoputter)
Posted: Sun Feb 15, 2004 4:39 am
by pwarren4
Our resident most excellent interior dis-assembler has graced this forum with step by step how to on dismantling the dash/console here:
http://forums.genvibe.com/zero...86055Enjoy!
Posted: Sun Feb 15, 2004 12:13 pm
by NovaResource2
Quote, originally posted by gogoputter »I don't smoke but I recently attempted to remove the cigarette lighter so I could plug in my cell and the entire cigarette lighter and assmbly came out about an inch but I could not separate the lighter from the receptacle. This is really odd but has anyone else had this problem? and....how does one get to this assembly to fix it. Any help is appreciated.thanks !!!I don't smoke either and I hate having to remove the lighter and store it somewhere when I want to use the outlet. While at the Philly auto show I got to see a 2004 up-close and one of the changes was a dash outlet without a lighter. Instead it has a black plastic, flip-down cover like the power outlet in the console. So what I did was go to the local GM dealership and get the 2004 Vibe part number. Because the 2003 lighter has a light ring around it and the 2004 cover doesn't I needed to order a new outlet with the cover.The part numbers are 88971514 (GMPartsDirect.com you can get them for $10.00 and $11.70.Use these 2 links for directions on how to change the outlet:
http://forums.genvibe.com/zerothread?id ... d?id=59402 other changes for the 2004 Vibe were cloth visors instead of the vinyl and the rocker panels (on 2-tone cars only). I purchased a pair of cloth visors but I'm waiting for the spring to buy the rockers. The parts numbers are:Driver side visor: 88972901 - dealer = $68.70 - GMPartsDirect.com = $39.16Passenger side visor: 88972900 - dealer = $68.70 - GMPartsDirect.com = $39.16Driver side rocker: 88973002 - dealer = $82.80 - GMPartsDirect.com = $48.84Passenger side rocker: 88973001 - dealer = $82.80 - GMPartsDirect.com = $48.84
Re: cigarette lighter (silverawd26)
Posted: Sun Feb 15, 2004 12:34 pm
by NovaResource2
They are only replaced if you can show "discoloration". Discoloration of the wheel arches will be replaced under warranty. If the wheel arches have a "sandblast" damage, that isn't covered because they claim it's "normal wear".My wheel arches have neither problem yet. I'm only doing it to prevent it from happening. So Pontiac won't pay to do it.
Re: cigarette lighter (pwarren4)
Posted: Sun Feb 15, 2004 8:19 pm
by gogoputter
really good info...thanks so much
Re: cigarette lighter (NovaResource2)
Posted: Sun Feb 15, 2004 8:21 pm
by gogoputter
thanks...within the month I'll have the flip down type as you described
Posted: Thu Mar 18, 2004 1:32 pm
Scott:Noticed on VibeChick's 04 she had the 03-styled lighter...glowing ring, no flip cover. Think it might just be the US 04's that have the flip top?Also, wasn't that flip top black? The one I got today is a beige/gray color...
Posted: Thu Mar 18, 2004 3:01 pm
by cdFxer
My flip-top is pretty black, maybe a slight charcol coloring to it.
Re: (cdFxer)
Posted: Thu Mar 18, 2004 3:04 pm
here's the one they sent me:
Posted: Thu Mar 18, 2004 9:21 pm
by Jahntassa
Mike, if i'm not mistaken, that's the cover for the 12v outlet in the storage compartment between the seats...
Re: (Jahntassa)
Posted: Fri Mar 19, 2004 4:39 pm
you're absolutely right.wonder if scott has the wrong part number there?
Posted: Fri Mar 19, 2004 8:46 pm
by scherry2
Quote, originally posted by NovaResource2 »They are only replaced if you can show "discoloration". Discoloration of the wheel arches will be replaced under warranty. If the wheel arches have a "sandblast" damage, that isn't covered because they claim it's "normal wear".My wheel arches have neither problem yet. I'm only doing it to prevent it from happening. So Pontiac won't pay to do it. they should still cover the "sandblasted" lower rocker. it isn't normal wear and GM knows it, they just don't want to fix it like many other vibe owners found out. they have pics of it on the TSB site at work and it sure looks sandblasted to me. discoloration... GM just likes to twist words around. sorry I go off topic.....
Re: (ragingfish)
Posted: Sat Mar 20, 2004 1:02 am
by NovaResource2
Quote, originally posted by ragingfish »you're absolutely right.wonder if scott has the wrong part number there? I got the same one when I ordered mine. They must have given me the wrong part number. It does not fit the dash (I tried). I was able to get the correct black one for the dash on eBay. It doesn't have the light ring but I don't care. I'm going to install the grey one on the rear hatch area and wire it directly to the battery (fused) so it's powered all the time.If anyone wants my lighter with light ring, make me an offer via IM or email.Wrong one:Correct one from eBay:BTW, the 2004 sunvisors are awesome! Cloth covered and when you move them to the side to block the sun, they slide back to cover more.Again, if anyone wants my vinyl 2003 sunvisors, make me an offer via IM or email.
Posted: Sat Mar 20, 2004 11:24 am
by cdFxer
Hey! I got ripped off then (lol)! My 2004 does not an extra slide out thing, if thats what ya mean? Also mine have a vanity mirror on the drivers side, but none on the drivers side, like your pictur shows. Perhaps another part number? Or maybe my Vibe was put together on Friday at beer:30?
