help with signature
Posted: Fri Feb 13, 2004 11:53 am
by Merzbow
I did the search thing and couldn't find anything so, how do I upload an image into my signature??
Re: help with signature (Merzbow)
Posted: Fri Feb 13, 2004 12:38 pm
The signature edit screen does not provide a way to upload an image file.Before the software upgraded last fall, you could go to some old fogotten post and upload an image, and then use the URL to that image in your signature.Since the upgradde, however, if you try to include a URL to an image uploaded to the forum in a post, the software stips the image refernce out. Smae thing happens if you upload an image and then want to dislay it in the post using the [IMG] and [/IMG] tags.So, for now, if you want to have an image in your signature, you need to upload it to the web somewhere else, some other webspace other than genvibe, adn then use the URL to that other site in your signature.If you right click on images in peoples signatures and select properties, you can see the URL to the image, that might give you an idea where other people have posted the pictures in their signatures. You may find some that are hosted on genvibe, but they were set up before the forum software upgrade.not sure if/when the ability to show an uploaded image will be back, until then you'll need to find somewhere else for the pic, and then you can include it in your signature
Re: help with signature (joatmon)
Posted: Sat Feb 14, 2004 2:03 pm
by Merzbow
Ok, thanks alot for the help I would have been sitting there trying to firgure it out for like 5 more hours. I'll screw with it when i get back from snowmobiling thanks again.
