Dash Rattle
Posted: Wed Feb 11, 2004 11:34 pm
by RIT
I, like most others, am still plagued with the ubiquitous dash rattle/buzz behind the stereo. I have stuffed foam in various places, but it still is there. It happens more frequently when the temp is cold, and occurs in the 4000 rpm range.Has anyone isolated what it actually is, and how have they fixed it? No, it is not coming from the cruise control module - it is more in the area behind the stereo, and near the center defroster ducts. It's driving me nuts ! PLEASE HELP !
Re: Dash Rattle (RIT)
Posted: Thu Feb 12, 2004 1:40 am
I vaguely remember someone having to foam the ducts to eliminate a rattle...Easiest way to isolate it is to remove the upper dash and find out for sure what causes it...
Re: Dash Rattle (ragingfish)
Posted: Thu Feb 12, 2004 2:07 am
by RIT
My concern is having the air bag blow up in my face. That would "rattle" me a lot worse then the dash buzz. Although, I may evenually have to do that - unless someone can pinpoint it for me.
Posted: Wed Mar 28, 2007 1:19 am
by shane_c
I'm still getting this rattle too. It sounds like it's behind the stereo or from the center of the dash behind the vent just to the right of the stereo. I had the stereo out last year and drove around to see if I could find it but it seemed to the right of the stereo opening. Any fixes yet?
Re: (shane_c)
Posted: Wed Mar 28, 2007 1:53 am
by Whelan
the only slight rattle i get is when the car is at idle there is a fast repetitive one, not such a big deal.I had a huge one this past winter but it was like 10 degrees for over a month and when the weather got warm, went away.
My rattles...
Posted: Wed Mar 28, 2007 3:57 am
by jkm311
The rattle you guys are getting is the one I have been lazy to fix. It's the A/C assembly, at least on mine. When it begins to rattle, I push on the un-used dummy button below the A/C controls, and it stops completely. Thus, in my case, I just need to tighten that assembly. Most likely going to do it this Saturday (nice weather, supposedly).My other rattle is coming from the corner of the dash by the day-runner headlight sensor, on the driver's side. THAT one, I have no clue how to stop. Anyone else have this at one point? Remedy?
Posted: Wed Mar 28, 2007 4:13 am
by VforVIBE
Quote, originally posted by RIT »I, like most others, am still plagued with the ubiquitous dash rattle/buzz behind the stereo. I have stuffed foam in various places, but it still is there. It happens more frequently when the temp is cold, and occurs in the 4000 rpm range.Has anyone isolated what it actually is, and how have they fixed it? No, it is not coming from the cruise control module - it is more in the area behind the stereo, and near the center defroster ducts. It's driving me nuts ! PLEASE HELP ! I had that same exact problem, here's what the report said:"PROBLEM:States vehicles has strange rattle type noise that comes from the dash area, seems to happen more when the engine is cold, heard with engine under load at 2400 RPMSCAUSE: LooseC2540 Buzz Type Coming from right side of column removed radio and part of dash to diagnose noise bracket for dash frame bolt loose reinstall1009 WP94 1.90 (N/C)"(sorry, no part number listed.)
