Car stereo dimensions
Posted: Tue Feb 10, 2004 12:43 am
by ullbergm
Anybody know where i can find specs on how big car radios are?I'm looking for the dimensions (ie. height, widht, depth, etc.)The reason im looking for this is that im going to see if i can mount my police scanner under my radio.btw, It's legal where i live to do that as long as you have a amateur radio license.
Re: Car stereo dimensions (ullbergm)
Posted: Tue Feb 10, 2004 4:43 am
by Jahntassa
Sure...go through Crutchfield, I think they have the dimensions on the "specs" page. Could be wrong tho..
Re: Car stereo dimensions (Jahntassa)
Posted: Tue Feb 10, 2004 6:38 am
by ullbergm
Quote, originally posted by Jahntassa »Sure...go through Crutchfield, I think they have the dimensions on the "specs" page. Could be wrong tho..couldnt find anything on crutchfield.. it just tells you the chassi code, not how big it is i have some more time now after work so ill try to find something on google.
Posted: Tue Feb 10, 2004 9:52 am
You want dimensions of the stock stereo?
Re: Car stereo dimensions (ragingfish)
Posted: Tue Feb 10, 2004 10:10 am
by ullbergm
No, im looking for the size of a half height radio.basically im trying to figure out if a half height radio plus my uniden 780 scanner will fit. i'm aware that i will probably have to move the uniden into a shell from a old radio, but im not sure the front panel of the 780 is small enough to fit underneath a radio.
Posted: Tue Oct 05, 2004 10:55 am
by Natron
Dimensions of the stock radio would be nice...
Posted: Tue Oct 05, 2004 1:53 pm
by Jahntassa
The vibe is a dual-DIN radio. You can fit two standard-size ISO/DIN mount radios into the spot. If your scanner is smaller than a standard aftermarket radio, it'll fit fine.
Re: (Jahntassa)
Posted: Tue Oct 05, 2004 9:15 pm
by ullbergm
Quote, originally posted by Jahntassa »The vibe is a dual-DIN radio. You can fit two standard-size ISO/DIN mount radios into the spot. If your scanner is smaller than a standard aftermarket radio, it'll fit fine.The problem is that i need to know what the size of a standard din radio is..
Re: (ullbergm)
Posted: Tue Oct 05, 2004 10:20 pm
by omarq
most all din radio will be about the same size.. just for reference Her's the dimensions on the Single-Din unit I have:HxWxD = 52 mm x 188mm x 161mm (2 1/16 x 7 3/16 x 6 3/8)Hope this helps.Omar
Re: (ullbergm)
Posted: Tue Oct 05, 2004 10:31 pm
by Nervous_Dog
The DIN standard is 2 inches high by 7 inches wide.DIN = Deutsche Industrie Norm
Posted: Wed Oct 06, 2004 1:53 am
by ullbergm
Thanks guys.
