AOL 9.0
Posted: Mon Feb 02, 2004 10:09 pm
by msmyer
I recently switched from 8.0 to 9.0 and am having a problem. I can not get any sound from AOL media player, IM's, sign offs/ons, or anything else on AOL. I can't seem to find a control panel for anything other than IM's and that is turned on. Any ideas? Thanks in advance....
Re: AOL 9.0 (msmyer)
Posted: Mon Feb 02, 2004 11:54 pm
by russ257
your first problem is that aol is your isp
Re: AOL 9.0 (russ257)
Posted: Tue Feb 03, 2004 12:43 am
by wicked1981
Did you try running the computer check up? It checks your computer and if it finds problems and fixes them. I hate AOL but I have it because my other half's family has AOL so im stuck with it. Now that we are in this subject whats a good IPS company to use?
Re: AOL 9.0 (wicked1981)
Posted: Tue Feb 03, 2004 1:32 am
by pwarren4
Quote, originally posted by wicked1981 »Now that we are in this subject whats a good IPS company to use?They all work fine as long as you DON'T USE THEIR SOFTWARE FOR BROWSING, ETC. The basic windows may not be as pretty, but the chances of it working are much better.As far as the original post question:AOL is notorious for putting out buggy software - give AOL a call and drill them for an update. One probably exists, they won't want to admit it though.
Posted: Tue Feb 03, 2004 4:12 am
by scherry2
Quote, originally posted by russ257 »your first problem is that aol is your isp ROFL
Posted: Tue Feb 03, 2004 12:03 pm
by Stang2Vibe
Quote, originally posted by russ257 »your first problem is that aol is your isp Ditto that big time. Years ago I had AOL and my g/f's sister still has it. I think it sucks more now than it did over 5 years ago when I last subscribed to it. Just about anything is better than AOL in my opinion.
Posted: Tue Feb 03, 2004 12:08 pm
by millster
To make an attempt at actually helping, is AOL the only thing that doesn't make sound? Does the computer still make its sounds when you startup or shutdown?
Re: AOL 9.0 (millster)
Posted: Tue Feb 03, 2004 7:44 pm
by msmyer
Quote, originally posted by millster »To make an attempt at actually helping, is AOL the only thing that doesn't make sound? Does the computer still make its sounds when you startup or shutdown?Yep...just no sound on AOL.
