New battery
Posted: Fri Jan 30, 2004 4:58 am
by DonB
I'm glad I got the new upgrade battery put in a week ago today, we had fifteen below this morning and as stiff as the car was I don't think it would have started with the old battery.
Re: New battery (DonB)
Posted: Sat Jan 31, 2004 12:30 am
by engine1
I just changed my battery after a very cold morning for this area just about killed the stock power plant! I checked the size and found that an AC Delco 85-7YR fits perfectly if you use the adaptar under it and provides 850 CA.............WOOOOHOOOO! Called my rep and got one n/c! Now it should crank at -40!
Re: New battery (engine1)
Posted: Sat Jan 31, 2004 12:51 am
by Raven
Quote, originally posted by engine1 » I just changed my battery after a very cold morning for this area just about killed the stock power plant! I checked the size and found that an AC Delco 85-7YR fits perfectly if you use the adaptar under it and provides 850 CA.............WOOOOHOOOO! Called my rep and got one n/c! Now it should crank at -40!How did you swing that deal? Please let us know ASAP. My dealer said the free replacement is only available in the USA.
Re: New battery (Sunny)
Posted: Sat Jan 31, 2004 12:32 pm
by engine1
I sell auto-parts for a living. One of those lines is AC Delco, I just called in a favor, and got one written off! But the point was that there is a very stong battery available that at the very least the dealer could pro-rate the battery in your vehicle and give you the value against one with higher CCA.
Posted: Sat Jan 31, 2004 4:35 pm
by ragingfish
What does that battery run MSRP-wise?
Re: New battery (ragingfish)
Posted: Sun Feb 01, 2004 2:39 am
by engine1
About 80 bucks(CAN) across the counter!
