Water leak at the top of rear doors
Posted: Wed Jan 14, 2004 8:54 am
by adventurer
Does anybody have a minor leak at the top seal on the rear doors?
Re: Water leak at the top of rear doors (adventurer)
Posted: Thu Jan 15, 2004 12:50 pm
by Altus
Nope -- I've had it at the top of my windshield after it was replaced, but never in the doors.I have noticed that - now that it's cold - I can hear road noise more from around the doors..... makes me wonder about the seals.....
Posted: Thu Jan 15, 2004 1:01 pm
by VibeChick
I had a water leak at the top of my front passenger door the first week I had my Vibe - water rolling down the A-pillar in a heavy rainstorm.When the tech lifted the seal off, a bunch of water poured out, so no need to try and prove the leak! They fixed it for me with no problem - same day I took it in.
Re: Water leak at the top of rear doors (VibeChick)
Posted: Fri Jan 16, 2004 1:28 pm
by adventurer
Well the dealer found out that BOTH rear window seals are leaking and bad. I told them that much. So they are going to replace them next week when they get the parts in. So I guess it's towels on the back seat until then.
Posted: Fri Jan 16, 2004 10:08 pm
by scherry2
Quote, originally posted by adventurer » Well the dealer found out that BOTH rear window seals are leaking and bad. I told them that much. So they are going to replace them next week when they get the parts in. So I guess it's towels on the back seat until then.you might want to have the tech fit the doors a couple of millimeters closer to the door frame. I watertest GM trucks and that is what I see when the doors leak. the door is not making solid contact with the door frame weatherstrip and water leaks by. just a suggestion
Re: Water leak at the top of rear doors (scherry2)
Posted: Wed Jan 21, 2004 9:13 am
by adventurer
Thanks, will do!
Posted: Thu Jan 22, 2004 9:10 am
by adventurer
Well I just lubed the somewhat dry doorseals and it has worked so far. Better than letting the dealer butcher it.
