Two problems with the 03 Vibe
Posted: Tue Jan 13, 2004 11:09 am
by abe98gt
Two annoying things...1. 6 disc in dash CD changer can be heard while playing...kinda a whirring sound...this isn't right is it? It shouldn't be!!!2. The weatherstripping that runs along the roof in front of the roof rack is wavy going up and down now. What can be done about it?
Re: Two problems with the 03 Vibe (silverawd26)
Posted: Tue Jan 13, 2004 11:45 am
by AKLGT
my cd changer makes a whirring sound when it changes discs. is that what you mean?
Posted: Tue Jan 13, 2004 11:56 am
by Jahntassa
Can't be any worse than the random noises the NAV disc makes...Just turn up the volume knob, that'll fix the CD problem.
Re: Two problems with the 03 Vibe (abe98gt)
Posted: Tue Jan 13, 2004 4:14 pm
by Stang2Vibe
My 6-disc changer only makes the whirring noise when ejecting/inserting/changing discs, that is normal. If it is making loud noises while playing the discs, you should have it checked out. Also, -note to everyone- do not ever play CD's with homemade adhesive labels on them in your car's CD player. When the CD warms up inside the player, it can cause the adhesive label to loosen and jam up the mechanism inside the player (especially with in-dash CD changers). My cousin did this to his Altima and the whole head unit had to be replaced because it was all gummed up with adhesive labels. Fortunately, they replaced it under warranty.As for the weatherstripping, I would have the dealer fix this. They will probably just remove it then reinstall it using some adhesive like ragingfish said. It should be covered under warranty.
Posted: Tue Jan 13, 2004 11:45 pm
by Reynoma
Quote, originally posted by abe98gt »Two annoying things...1. 6 disc in dash CD changer can be heard while playing...kinda a whirring sound...this isn't right is it? It shouldn't be!!!I also hear the disc "spinning" between songs on discs. I always thought it was because I don't use original store cds...I always burn a copy on to some cheap blank CDs to keep in the car...I'm never sure if those are perfectly round.
Re: Two problems with the 03 Vibe (Reynoma)
Posted: Wed Jan 14, 2004 12:12 am
by drunkenmaxx
mine made a "spinning sound" (single disk) when i first got it, i took it back and got a new cd player, prob fixed
Posted: Thu Jan 15, 2004 5:58 am
by SARGE
I always have burnt CD's in mine, and have not experienced any problems yet. I love having the changer in the dash. My Corvette's changer was installed in the rear. That makes changing discs while driving a real pain. At least it didn't have a trunk to mount it in.
Posted: Thu Jan 15, 2004 9:09 am
by Merzbow
Hey I don't have a 6-disc changer in my 2003, how ever some cds I play make a grinding noise when I hit the brakes, like it's off balance or something. Some cds don't do it at all but otehr do it when i let off the gas! I dont know what the deal is.
Re: Two problems with the 03 Vibe (Merzbow)
Posted: Thu Jan 15, 2004 9:40 am
by ragingfish
Quote, originally posted by Merzbow »Hey I don't have a 6-disc changer in my 2003, how ever some cds I play make a grinding noise when I hit the brakes, like it's off balance or something. Some cds don't do it at all but otehr do it when i let off the gas! I dont know what the deal is.Sounds like the player isn't properly holding the CD, and it's being allowed to "tilt" when you hit the brakes...Would advise having it looked at by the dealer...I recall hearing of similar issues with other owners now that I think about it...
Re: Two problems with the 03 Vibe (ragingfish)
Posted: Thu Jan 15, 2004 10:43 pm
by pmh013
Single CD player had an issue. When you braked moderately, you could hear the CD rubbing on something inside the player.Your dealer can order in a new player, and replace it in a few hours.This one is an easy fix.
