using the jack the 2nd time
Posted: Mon Dec 22, 2003 9:30 am
by ullbergm
man, i need a drink. i about had a heart attack going home from work tonight.I was driving somewhere around 45-50 when i hit a piece of wood that someone had left on the road. Scared the sh*t out of me.To make it worse when i pulled over the car got wedged up on top of the wood and i was halfway down a ditch. So when i tried to use the jack it lifted the rear wheel instead of the front one. I was finally able to lift it high enough that i could get the wood out from under the car and i pulled the car over to a flat spot. (the tire was already messed up, so it didnt matter)Did i mention that people go 60+ on this 2 lane road.. didnt feel very comfortable changing a tire while trying to avoid getting hit.Since people wouldnt believe me when i said i hit a big-(removed) piece of wood i took it home as a trophy. /me is going to get a drink and watch some tv.. edit: added the pictureedit again: hmm.. cant get the picture to show up.. going to try my own website instead
Re: using the jack the 2nd time (ullbergm)
Posted: Mon Dec 22, 2003 9:34 am
ouch. glad you didn't lose control!!!since you gotta replace a wheel, maybe it's time for some aftermarket wheels?
Re: using the jack the 2nd time (ragingfish)
Posted: Mon Dec 22, 2003 9:37 am
by ullbergm
Quote, originally posted by ragingfish »ouch. glad you didn't lose control!!!since you gotta replace a wheel, maybe it's time for some aftermarket wheels? yeah, there were oncoming traffic but i pretty much kept moving straight after i hit it, im still shaking.. scared me to death.hehe, ill try.. not sure if i can fit it in the budget.. thats quite a bit of money.. It doesnt look like its a fixable thing.. it's bent about 2 inches in..
Posted: Mon Dec 22, 2003 9:55 am
even if it weas fixable, things just never seem "right" after they've been repaired...something always seems off...
Posted: Mon Dec 22, 2003 9:59 am
by ullbergm
Quote, originally posted by ragingfish »even if it weas fixable, things just never seem "right" after they've been repaired...something always seems off...yep..i sold some stuff on ebay and i was going to get a projector and a 100-120" motorized screen for my home theatre.. figures.. now i'll be buying tires instead..
Posted: Mon Dec 22, 2003 11:03 am
That is a significant piece of wood! I wouldn't want to fix that wheel, I would never trust it to be right, and wheels/tires are critical to having a safe, road worthy car. If that's the kind of stuff you are likely to have on those owensboro roads, it might not be worth spending money on expensive wheels, get some more steelies.
Posted: Mon Dec 22, 2003 11:12 am
by cohocarl
That sucks. That was obviously a very strong hit. Hope nothing else in the suspension was damaged.The wood probably fell off of some dumbash's pee-cup truck that was overloaded with wood so he can heat his house or garage.Glad you weren't hurt.
Re: using the jack the 2nd time (joatmon)
Posted: Mon Dec 22, 2003 11:13 am
by ullbergm
Quote, originally posted by joatmon »That is a significant piece of wood! I wouldn't want to fix that wheel, I would never trust it to be right, and wheels/tires are critical to having a safe, road worthy car. If that's the kind of stuff you are likely to have on those owensboro roads, it might not be worth spending money on expensive wheels, get some more steelies.yeah, its pretty heavy. i guess im lucky it wedged itself under the frame (right where you are supposed to put the jack) instead of under something important..what are the chances it messed up something else (suspension, etc.)?It was pulling to the side of the spare tire on the way home, but i just assumed it was because of the spare.. It's the first time ive seen major crap on the road, but i may go for the cheap tires because of cost..
Re: using the jack the 2nd time (cohocarl)
Posted: Mon Dec 22, 2003 11:15 am
by ullbergm
Quote, originally posted by cohocarl »That sucks. That was obviously a very strong hit. Hope nothing else in the suspension was damaged.The wood probably fell off of some dumbash's pee-cup truck that was overloaded with wood so he can heat his house or garage.Any idea if the warranty will cover any of this? and any other damage (suspension) that might have happened? i did get the extended warrantyQuote, originally posted by cohocarl »Glad you weren't hurt.thanks
Posted: Mon Dec 22, 2003 12:42 pm
by threekrows
Doubt warranty will do anything.But insurance would....
Posted: Mon Dec 22, 2003 2:05 pm
by Vibe
OUCH!!!! I think a fifth of Jack Daniels would be in order !!! Sorry of your misfortune. James
Re: using the jack the 2nd time (threekrows)
Posted: Mon Dec 22, 2003 5:08 pm
by cohocarl
Quote, originally posted by threekrows »Doubt warranty will do anything.But insurance would....I'd at least have the dealer take a look at it to make sure, and I'm assuming your insurance co. would cover it. I had a chunk of ice fall off a concrete truck the other day and it bounced up and whacked out part of my lower grill and hit my a/c condenser. I don't think the condenser is leaking, but I'm going to head into the dealer and have them look at it. If that needs replacing, I'm giving my ins. co a call.
Re: using the jack the 2nd time (Salsa!)
Posted: Mon Dec 22, 2003 9:34 pm
by ullbergm
Quote, originally posted by Salsa! »Didn't you see that "sucker" piece of wood on the road???? Anytime I see something I try to avoid it.... I have seen smaller stones do damage to a wheel!You're lucky you didn't kill yourself hitting that!But next time Keep Your Eyes on the RoadIt was pitch black and one of the oncoming cars flashed his lights at me, probably to warn me about the wood. It had the oposite effect, i looked up at his car and then WHAM. I did start to slow down when he flashed his lights thou..I'm lucky it wedged itself under the beam you put the jack on instead of under something more important under the car..
Posted: Mon Dec 22, 2003 9:41 pm
by ullbergm
Quote, originally posted by Salsa! »Oh sorry...didn't realize it was at night.... No problem I just with i could have avoided it.. this pretty much sucks..
Re: using the jack the 2nd time (silverawd26)
Posted: Tue Dec 23, 2003 12:51 am
by ullbergm
Quote, originally posted by silverawd26 »That to see you are ok man. The main thing. Parts can be replaced, lives cant. trueQuote, originally posted by silverawd26 »Check out
http://www.tirerack.com for the steelie and hubcap. They will prob charge you around $50-$80 for the rim/wheel cover. The tire (depending on what you have) will cost you abother $80 or so. Also, I would almost bet your alignment is off. Better get that checked. Hope this information helps!Thanks, i may do that or go with some nicer rims.. its a lot of money thou..The dealer quoted me $130 + labor if i have them do it.
