Do the Vibe and Matrix use GM OBD2 port?
Posted: Wed Dec 17, 2003 4:22 am
by abe98gt
I bought one of these yesterdayhttp://users3.ev1.net/~chauvin555/LS1M/and was wondering if I could also use it on my Vibe. What kind of OBD2 port does the Vibe use? I hope it is the GM one. Does the Matrix use the same one as the Vibe (I would assume so)...Thanks
Re: Do the Vibe and Matrix use GM OBD2 port? (abe98gt)
Posted: Wed Dec 17, 2003 5:29 am
by ragingfish
OBD2 ports are standard across the board.Any car built 96 and later should be compatible.
Re: Do the Vibe and Matrix use GM OBD2 port? (ragingfish)
Posted: Wed Dec 17, 2003 1:00 pm
by threekrows
Like raging said,it should work for generic codes.But the vibe doesn't have as much info available on a scanner compared to regular(non-toyota)GM cars.Some codes are flashed on the dash.(I think the one I dealt with was a cruise control problem and flashed codes for the cruise on the dash)
