Part # for the small, rectangular plate next to the driver-side coin holder?
Posted: Wed Dec 17, 2003 12:02 am
by Psychobroker
Does anyone know the GM part # for the small, blank insert/plate adjacent to the driver side coin holder and security light? I am almost done with my sub install, but need to order a few blank plates for the amp on/off switch, and just in case I screw up lol. I've already used the one provided for the bass control knob. Thanks in advance!
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (Psychobroker)
Posted: Wed Dec 17, 2003 12:37 am
by NSimkins
From: http://forums.genvibe.com/zero...71278Quote, originally posted by ragingfish »Got the part in today! Turns out it's the right one! So, if you're looking for extra blank plates for the left of the steering wheel, or to replace the little coin slots under the e-brake, the part you need is:88970565 COVER $2.75
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (NSimkins)
Posted: Wed Dec 17, 2003 2:27 am
by Psychobroker
Sorry about that...I didn't even know how to word my search for that part lol . Thanks Nick!
Posted: Wed Dec 17, 2003 2:59 am
by NSimkins
Quote, originally posted by Psychobroker »Sorry about that...I didn't even know how to word my search for that part lol . Thanks Nick!No need to apologize - it took me a bit to find it but I did remember seeing that part number from the past.
Posted: Wed Dec 17, 2003 5:30 am
by ragingfish
Don't forget the same plate can replace the pesky coin holder under the e-brake as well!
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (ragingfish)
Posted: Wed Dec 17, 2003 9:46 am
by Psychobroker
Yep, thanks for the reminder. That might be used for red under-dash LED's, if I decide to go that route
Posted: Wed Dec 17, 2003 10:50 am
by ullbergm
i put my garage door opener down there.the momentary push button came from radioshack.
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (ullbergm)
Posted: Wed Dec 17, 2003 11:01 am
by ragingfish
That's pretty cool!What did you do, disassemble the transmitter and tap into it?
Posted: Wed Dec 17, 2003 9:58 pm
by ullbergm
Quote, originally posted by ragingfish »That's pretty cool!What did you do, disassemble the transmitter and tap into it?Yep, it's really easy. All i did was open it up and solder two wires to the leads from the push button and then run them to the button by the coin holder.I like it, looks nice and clean.
Posted: Thu Dec 18, 2003 1:31 pm
by ragingfish
Where's the transmitter? Just floating around back there?
Posted: Thu Dec 18, 2003 9:54 pm
by ullbergm
I made the wires from the button to the opener about a foot long and then i attached the opener to some of the wiring behind the panel with some ziplocks to keep it from moving around.It was kind of a pain to lie on my back and try to ziplock it in place, but now it doesnt rattle or move around.
Posted: Tue Jan 27, 2004 3:23 am
by drummerdude
Talk about a pain in the (removed) when the openers battery goes dead!
Posted: Tue Jan 27, 2004 12:25 pm
by AKLGT
i've got my heated seat button where the useless coin holder is. the security one is next to it and the last blank is being reserved for my independant foglight switch once i have more time and space to figure that out. plus, my unichip switches will probably go in the compartment where they are just shoved in currently, but will most likely mount them permanantly in there so it looks custom.
Re: Part # for the small, rectangular plate next to the driver-side coin holder? (trdvibe)
Posted: Fri Oct 07, 2005 8:19 am
by VibeFever
Yeah I just recently installed an aux input adaptor, and ran the stereo cables under the carpet to the useless coin holder below the e-brake. I mounted a jack there in one of the blank panels from the dash. I have a short pigtail which now plugs between my mp3 player and the jack.
