Windshield washer nozzel got blocked
Posted: Mon Dec 15, 2003 2:15 am
by Sub-Vibe-R
When I took my Vibe yesterday, the windshield was completly forzen. So I started the winshield washer to clean it up and nothing been spit from the nozzle.... The pump was working. I thought it was the ose unplugged again, but not...I scratched the windshield and drove a little bit.After a while, I tried again the washer and then passager starts working. But the driver one still not working.I don't know if it is ice or something else who stuck the ose.Anyone has a trick for this??I don't not want to lose a lot a time and go to the dealer to ahve it fixed...
Re: Windshield washer nozzel got blocked (Sub-Vibe-R)
Posted: Mon Dec 15, 2003 2:36 am
by ArcsVibe
Ben do you have a garage where you can park your car for a few hours? The nozzle might be frozen , it happened to me with my Cavalier. I parked it inside in a heated garage and it worked....
Re: Windshield washer nozzel got blocked (ArcsVibe)
Posted: Mon Dec 15, 2003 2:42 am
by drunkenmaxx
i would definitely say it is frozen, mine just did the same thing the past few days. (finally got below freezing here, and got a sissy snow)
Posted: Mon Dec 15, 2003 2:43 am
by pmh013
Do you have summer or winter fluid in? I found that I had to keep diluting my summer fluid (the pink kind) with winter fluid (the blue kind) to prevent it becoming a slushy mess. You've been using the strainer when you fill, I hope.Your best bet is to find a mall with heated parking & a movie theatre. Go see a movie, and when you're done, it should be thawed out. Pump a lot of fluid through it, and fill up with winter fluid.
Re: Windshield washer nozzel got blocked (pmh013)
Posted: Mon Dec 15, 2003 3:57 am
by Sub-Vibe-R
I always been using winter fluid washer....When I picked up my car, I notice a lot a condensation on the windshield, so it can be very possible that the ose got condensation in it as well. And as my Vibe was in my parking spot for a while, the winshield washer just get back to the tank...Unfortuantly, I do not have an heated garage, and none of my friend/relative has one in my area...May be by driving my car for a long time, the heat from the engine will melt the ice in the ose.By chance, the temperature should go above the freezing limit. So I'll remove all the snow on my baby (we got 12 inches last night) and park my car right under the sun.
Posted: Mon Dec 15, 2003 4:23 am
by Charlievibe
Quote, originally posted by pmh013 »Your best bet is to find a mall with heated parking & a movie theatre. Go see a movie, and when you're done, it should be thawed out. Pump a lot of fluid through it, and fill up with winter fluid.This is off the topic being discussed, but you have heated parking? My cousin told me that he used to have to plug his engine heater in, but he NEVER told me about heated parking. That sounds cool.As for the frozen sprayer, my Sunbird used to do this when I was living in Colorado. If I would use it, then leave the car outside and it would drop below freezing, the very tip would freeze. I solved this problem by pouring warm, not hot, water slowly over it. Where you live, this may not be practical, but just a thought.
Re: Windshield washer nozzel got blocked (Charlievibe)
Posted: Mon Dec 15, 2003 1:09 pm
Also can try a hair dryer or heat gun (just don't drop it in the snow!) Isn't a permanant fix, but will help you determine if it's just frozen, or a bigger problem.My money is on frozen.
Posted: Mon Dec 15, 2003 2:44 pm
by Vibe
Mine does the same thing on a heavy frost. I have always used winter washer fluid and even purge the nozzles after a wash by operating them.I guess the thin layer of frost which is ice is just enough to do it. RATHER ANNOYING!!James (Vibe)
Posted: Mon Dec 15, 2003 10:05 pm
by pmh013
Quote, originally posted by Charlievibe »This is off the topic being discussed, but you have heated parking? My cousin told me that he used to have to plug his engine heater in, but he NEVER told me about heated parking. That sounds cool.When I was in university, there was a mall in that city that had a heated underground parkade. When your car needed to thaw out, you'd go for a movie at the $2 theatre at the mall, and park your car in the parkade. When you got out, everything was nice & thawed out. I had a friend that had to go see a movie every time she wanted gas, because her gas lid was always frozen shut. That place was awesome, but maybe they are few & far between, because the only seem to be in that city.
Posted: Mon Dec 15, 2003 11:24 pm
by Sub-Vibe-R
I removed the 12 inches of snow on my car yesterday evening and I tested again the washer... Now 2 out of the 3 sprayer work on driver side....
Posted: Mon Dec 15, 2003 11:49 pm
by drunkenmaxx
>"dont be sad, cause 2 out of 3 aint bad..."
Posted: Wed Dec 17, 2003 12:08 pm
by SCTM
Easiest way is to put your fingers over noozle to get them warm enough then activate washer. I do that when they are frozen at work or wallmart parking lot... away from home and all equipement already mentionned (hot water - hair dryer - garage).With our "yo-yo" temperature it's normal to have these frozen, BTW do you have winter blades on? There is special at Lebeau (known by Quebec guys) $39.99 for 2 winter blades + Aquapel treatment.
Re: Windshield washer nozzel got blocked (SCTM)
Posted: Thu Dec 18, 2003 1:38 am
by ArcsVibe
What is exactly the "Aquapel" system......
Posted: Thu Dec 18, 2003 2:19 am
by Sub-Vibe-R
Quote, originally posted by SCTM »BTW do you have winter blades on? There is special at Lebeau (known by Quebec guys) $39.99 for 2 winter blades + Aquapel treatment. Sure, I bought them last week. I put some Teflon wiper. I bought them at Canadian tire for about 15$ each....
Posted: Thu Dec 18, 2003 9:33 am
by SCTM
ArcsVibeAquapel is windshield treatment (such as Rain X and others likes stuff)Aquapel is way ahead the others
http://www.ppg.com/gls_aquapel/main.htmSubVibeRI did the same last year (bought Teflon from CTire) and had them back when I saw "Lebeau special". Why don't you do the same... and get Aquapel in bonus
Posted: Thu Dec 18, 2003 9:29 pm
by ArcsVibe
Merci beaucoup! Thank you for the information....guess I will have to drop by Lebeau for a visit!
