Steering not responsive
Posted: Sat Nov 29, 2003 11:30 pm
by P POPPR
I'm not used to front wheel drive so this could be normal. The steering has about a 1/2 second lag. When driving straight on the highway it is most noticeable. When making the minor corrections to keep the car in its lane, the wheels do not immediately respond to the movement of the steering wheel. Anyone else notice this?
Re: Steering not responsive (P POPPR)
Posted: Sun Nov 30, 2003 12:28 am
by MadBill
The response on my Vibe feels as good as most vehicles, front or rear drive. It is definetly crisper with my big low profile Firestones, but even with the snowtires it isn't mushy. Unless your last car was a Corvette or BMW, you Vibe must have a problem. (assuming the tires aren't at 20 psi!)
Re: Steering not responsive (MadBill)
Posted: Sun Nov 30, 2003 3:47 pm
by Stang2Vibe
Quote, originally posted by MadBill »The response on my Vibe feels as good as most vehicles, front or rear drive. I agree. I can't pull as tight of a turn with my Vibe as I could with other cars I've owned but steering response, especially on the highway has never been a problem. Might have something wrong with the car, there. The higher center of gravity causes me to lose some handling ability, but no problems with steering response.
Posted: Wed Dec 03, 2003 8:07 am
by P POPPR
Quote, originally posted by MadBill »The response on my Vibe feels as good as most vehicles, front or rear drive. It is definetly crisper with my big low profile Firestones, but even with the snowtires it isn't mushy. Unless your last car was a Corvette or BMW, you Vibe must have a problem. (assuming the tires aren't at 20 psi!)Bill you get the star. The Vibe is my wifes car and I don't drive it much. I drive the Vette or the Durango. The air pressure is correct and the fluid is fine. I went to a local dealer and test drove another Vibe. Steering feels the same as her car.
Posted: Wed Dec 03, 2003 2:49 pm
Having not driven anything but Tin Indians, I find the Vibe's steering to be exceptionally responsive...Guess I'll have to test drive a Vette next time and see how it compares...
Re: Steering not responsive (ragingfish)
Posted: Wed Dec 03, 2003 10:22 pm
by goodvibe
Stock Vibes need a moment to 'take a set' because of a higher center of gravity, moderate spring rates and bushing compliance. The base shocks are also a little soft for transitions. The Gt is a bit better. Vibes track fine and the steering has no slop in it. Some TRD/Pro Kit springs would help alot, are relatively cheap and ride fine. While you're at it, get a progress rear bar and maybe a STB.
Re: Steering not responsive (goodvibe)
Posted: Wed Dec 03, 2003 11:58 pm
by drunkenmaxx
mine out performs the old cavy like a charm. i don't, however, know what a base feels like, and i have no idea weather or not the awd suspension makes for better handling or what. people who have driven mine do say that the steering is tight.
