F350 vs RX-7 Video
Posted: Mon Nov 24, 2003 6:02 am
by kaybeejay
Re: F350 vs RX-7 Video (kaybeejay)
Posted: Mon Nov 24, 2003 6:50 am
by Sub-Vibe-R
Wow, This Ford is not stock for sure.And what somke behind the truck... It pump oil somewhere
Posted: Mon Nov 24, 2003 7:19 am
by Big_Red
Kick (removed) ride.....
Re: F350 vs RX-7 Video (Big_Red)
Posted: Mon Nov 24, 2003 7:28 am
by MadBill
There are amazing chips out for diesels that add like 200 HP by adding a huge amount of fuel, in order to use all the available air. That's why they smoke like blast furnaces. Also, dumping in tons of nitrous works just like on gasoline engines. Even still, the board showed 11.42 sec. for the quarter! Unless the guy has somehow stripped 2,000 lb out of the truck, he would probably need 700 HP to turn such a speed. Awesome!
Re: F350 vs RX-7 Video (MadBill)
Posted: Tue Nov 25, 2003 7:44 am
by Lancer
I've even seen a set up using nitrous, a chip, and propane gas. The Propane would help reduce the amount of smoke and give better MPG.Check out
http://Bullydog.com for trucks.
