Storage compartments rinky-dink closures: SOLVED!
Posted: Sun Sep 01, 2002 7:09 am
by NovaResource
I figured out what the problem is and an good solution. The problem is the door and latch are too far away from the hole in the underside of the shift housing. If you pull at the door it opens very easily. What I found was, if I lifted the door slightly, the latch holds better. So I removed the door from the housing and saw that it has 2 legs at the bottom of the door that sit in 2 grooves on the floor. I cut 2 small pieces of felt (about the size of a postage stamp) and layed them on the grooves. Then layed the legs at the bottom of the door into the grooves with the felt inbetween. The felt lifts the door slightly and allows the latch to engage the hole better. Now it's nice and tight.
Re: Storage compartments rinky-dink closures: SOLVED! (NovaResource)
Posted: Sun May 30, 2004 12:36 pm
by Fialchar
A post that's almost two years old that's still helpful and handy. Thanks Nova, I think I'll go ahead and bump this one back up for others
Posted: Sun May 30, 2004 2:06 pm
by 03VibeGT6Spd
Thanks to both of you!I have been planing on getting down there and checking into fixing that. Now it'll be easy!
Posted: Sun May 30, 2004 2:08 pm
Kudos to Scott on this one!Works fantastically!
Posted: Tue Mar 01, 2005 9:14 am
by cieglo
Great idea, thanks. that door popping open (like when I hit LIFT ) all the time drives me nuts.
Posted: Mon Dec 01, 2008 6:48 am
by joecoolinatl
i need to do this to mine this week
