Camber kit?
Posted: Fri Nov 14, 2003 2:01 pm
by SkateForLife86
Is it necessary to get a camber kit with springs that drop as low as 2" or lower i.e. sportlines. Or is a four wheel alignment after the installation enough?thanks
Re: Camber kit? (SkateForLife86)
Posted: Fri Nov 14, 2003 2:36 pm
by engine1
When they check your alighnment they will tell you if you need a camber kit to bring it back to within spec! Maybe maybe not
Posted: Sun Nov 23, 2003 6:28 am
by BiologicalAn
at the performance shop i went to recommended a camber kit for the rear wheels. it was only $25.
Re: Camber kit? (BiologicalAn)
Posted: Sun Nov 23, 2003 10:13 am
by MadBill
Since the Vibe (non-AWD anyway) rear suspension is a trailing swing arm, the camber does not change with ride height, thus any need for a camber kit to correct same would not relate to lowering springs, just factory variations, impact damage, etc.
