Compartment below radio
Posted: Wed Nov 12, 2003 8:39 am
by PhiDelt
Does anyone else have the problem of the compartment below the radio just coming open at times? I don't know why it does it but it only does it sometimes. Could use any help. Also if anyone knows if the back windshield sprayer spays or if it should just let the stuff flow down the back windshield.
Re: Compartment below radio (PhiDelt)
Posted: Wed Nov 12, 2003 9:02 am
by Raven
Mine pops open if I hit the shifter knob. I think the rear does not spray.
Re: Compartment below radio (Sunny)
Posted: Wed Nov 12, 2003 9:13 am
by MadBill
Some seem to pop open, some don't. The rear dribble is normal. It looks lame, but it does get the juice where you need it.
Posted: Wed Nov 12, 2003 9:34 am
For fixes for the compartment popping open, check outhttp://forums.genvibe.com/zerothread?id=777 andhttp://forums.genvibe.com/zerothread?id=5828For the rear window washer, check out http://forums.genvibe.com/zerothread?id ... ad?id=1913(bottom line, that's the way it is)
Re: Compartment below radio (joatmon)
Posted: Wed Nov 12, 2003 12:20 pm
by geezer
I used the foam tape method to fix mine. It used to come open every mile or two and overnight when parked -- it hasn't come open by itself since the repair.
Posted: Fri Dec 12, 2003 1:42 am
by 17tobyracing
We had the same problem with ours popping open when driving over bumps. We took it back top the dealer and they replaced and adjusted the latch. I figured we paid enough for the car to not have to do this ourselves or use tape.
Posted: Tue May 18, 2004 5:23 am
by jennifer0801
Mine did the same thing...drove me crazy.I took it to the dealer and they replaced it with a piece that had a longer clasp thing. It hasn't happened since. But now, the little compartment on the left of the steering wheel started popping open. Had to put velcro on it to keep it shut.
Re: Compartment below radio (jennifer0801)
Posted: Wed May 19, 2004 7:15 am
by Herb
Never had the chance to let that particular problem develop. I put full length box of tissues in the rectanglular bin right in front of that compartment.This serves a few purposes, hiding from view that there is a storage compartment there, holding the tissue box in an easily accessable location, and now apparantly to keep the bin closed.
