				First cold morning and almost didn't start....
				Posted: Sun Nov 09, 2003 11:16 pm
				by robdog
				Is there any way I could get a replacement battery under warranty.  This morning the temp in the vibe said 25 degreees.  It barely turned over.  I am sure that a few more cold mornings like that and I am sure to need a jump start.  I need more CCA's.  Any advice so I don't have to buy another battery......I know there have been threads about this, just wondering if anyone has had problems now that the temps are getting colder.......Thanks
				Re: First cold morning and almost didn't start.... (robdog)
				Posted: Sun Nov 09, 2003 11:29 pm
				by Sub-Vibe-R
				As soon as the temp goes down, I notice starting is even worst.This week-end, the temps goes at -1c (30F) and it was cranking very slowly. I'm affraid about the -20, -25c (-4, -13f) coming within the next week....
				Re: First cold morning and almost didn't start.... (Sub-Vibe-R)
				Posted: Sun Nov 09, 2003 11:35 pm
				This morning here it was about 30F (-1C), and mine was noticeably slower to crank.  I used to think the battery problems were only for those where it got really cold.  Now I'm not so sure.
				Re: First cold morning and almost didn't start.... (joatmon)
				Posted: Sun Nov 09, 2003 11:59 pm
				by Sub-Vibe-R
				quote:This morning here it was about 30F (-1C), and mine was noticeably slower to crank.  I used to think the battery problems were only for those where it got really cold.  Now I'm not so sure.Mine did the same as yours. So can you imagine what will be the result at -15F....
				Posted: Mon Nov 10, 2003 12:02 am
				Luckily, it should never get that cold this far south.  I feel sorry for you, both for having to put up with it that cold and for what you battery will do
				Posted: Mon Nov 10, 2003 12:45 am
				by Lee
				Mine too was slow to crank (about -8) Funny though, I really did not notice too much of a problem last winter!  (probably because last winter we did not get really cold weather early in the year, and as soon as it turned cold I would plug in whenever possible)
				Re: First cold morning and almost didn't start.... (Lee)
				Posted: Mon Nov 10, 2003 6:21 am
				by Jahntassa
				It's just a really tiny battery. I think the electrical system was built to just BARELY sustain the car.. I'm already looking at a high-output alternator, along with an Optima battery to supply my add-on electronics. Which is sad..And please don't flame me for putting an outrageous amount of electronics in my car! I know some of you find it silly and rediculous, but y'know..it's gives me a hobby..
				Re: First cold morning and almost didn't start.... (Jahntassa)
				Posted: Mon Nov 10, 2003 6:41 am
				by Savoy
				"And please don't flame me for putting an outrageous amount of electronics in my car! I know some of you find it silly and rediculous, but y'know..it's gives me a hobby.."Shine on..-Savoy-
				Posted: Mon Nov 10, 2003 7:07 am
				by Flip-Side
				quote:It's just a really tiny battery. I think the electrical system was built to just BARELY sustain the car.. Sure seems that way.  Sure GM did it just to save some cash.  Thankfully I live in a warm state, but when I visit Michigan in the winter I can tell the battery has to go.  Like everyone has noted, my car barely starts in the cold.  My wife had to have the car jumped once just to get enough juice to get it to turn.  I hope the recall happens soon...
				Re: First cold morning and almost didn't start.... (silverawd26)
				Posted: Mon Nov 10, 2003 9:23 am
				by millster
				quote:I think I am going to purcahse a Red Top Optima Battery and say **** GM.Likewise for me, I think.  It got down to 9F last week, and I really didn't think the car was going to start.  Luckily for me, it did but I don't know that I want to take that chance any longer.  It's going to get colder before it'll get any warmer.
				Posted: Mon Nov 10, 2003 9:28 am
				by millster
				Now that sounds like a plan!  I believe I would be up for it if you could work something out.
				Posted: Mon Nov 10, 2003 9:44 am
				by millster
				  Sounds good.  Yes, I would think that's strong enough.
				Posted: Mon Nov 10, 2003 10:58 am
				by Flip-Side
				quote:I will see what I can do. I know the Red Tops rate at like 800 CCA's, so that should be strong enough I would think. Considering the new ones coming from the TSB are less than 600 CCA's, it will be more than sufficient having 800.  Red Tops are some of the best sealed, reliable, mountable, and powerful batteries around.
				Re: First cold morning and almost didn't start.... (Flip-Side)
				Posted: Mon Nov 10, 2003 12:29 pm
				by andre
				It's been -15c here a few mornings and haven't had any problems with it starting. It's only about 3 weeks old though. Once the temp realy starts to fall I may have to plug in the block heater to be sure it will start.
				Re: First cold morning and almost didn't start.... (andre)
				Posted: Tue Nov 11, 2003 1:10 am
				by philndz
				quote:It's been -15c here a few mornings and haven't had any problems with it starting. It's only about 3 weeks old though. Once the temp realy starts to fall I may have to plug in the block heater to be sure it will start.You mentioned your car is only 3 weeks old.....i would be interested to see if it has the same battery as our older vibes......how many CCA's do you have?
				Posted: Tue Nov 11, 2003 1:13 am
				by NSimkins
				quote:That TSB should be out. Yes, it should - I've been concerned with starting myself and its only been in the 20's.  I'll have a call in this week to get an update on this issue.
				Re: First cold morning and almost didn't start.... (NSimkins)
				Posted: Tue Nov 11, 2003 2:06 am
				by etoop
				I'll check mine after work.  I picked my 2004 up in late August.  The weather has been about 15f at night all this week and I've left my car outside without any issues.
				Re: First cold morning and almost didn't start.... (etoop)
				Posted: Tue Nov 11, 2003 6:48 am
				by red
				its going to drop down to -25*F by this weekend with about -15*F during the days..curious to see how she will turn over...i will have to leave it out to find out to see if as the car/battery gets older, it gets weaker......they can come tow it if it doesnt start, suits me fine../maybe get the point across....i wonder if my snowmachine has a bigger cca than that?  may have to substitute the snogo battery for mine if it does!!! LOL
				Re: First cold morning and almost didn't start.... (red)
				Posted: Tue Nov 11, 2003 10:17 am
				by pmh013
				I've seen grain augers with bigger batteries than the Vibe has.
				Posted: Tue Nov 11, 2003 10:53 am
				by JohnC
				Is there a larger CCA battery that will fit in the battery location? it seems like it's a bit small.
				Posted: Wed Dec 19, 2007 11:08 pm
				by patrickogrady
				Since the winter set in here, it's been -10 to -20C. The car is taking 2-3 cranks before it "catches." I have the "running on 3 cylinders" engine behaviour when it finally does start, just for a second.
				Posted: Wed Dec 19, 2007 11:20 pm
				by northvibe
				the stock battery is weak..after my new battery and spark plugs, the car would fire up better but still on those negative days it would take a couple turn overs to get going.
				Posted: Wed Dec 19, 2007 11:23 pm
				by etoop
				Wow talk about revibing  and old topic
