Heat and engine question
Posted: Fri Nov 07, 2003 2:27 am
by Frosty Girl
Hi everyone -Wow! I haven't posted on here in ages. Anyway I also have a heat question. The last week or so we've had fairly cold weather, but my question is - are everyone's engine gages still at about half way and does your heat seem warm? My car is taking forever to warm up, I have about a 20 minute drive to work and by the time I get to work my heat is finally starting to warm up, but my engine light is still way down. My dad said something about my thermostat....should I call and take it in? Any other suggestions?Thanks!Frosty Girl
Re: Heat and engine question (Frosty Girl)
Posted: Fri Nov 07, 2003 2:36 am
It has been a while. welcome back It hasn't gotten cold here yet, but last winter it took me about two miles to start getting warm air out of the heater. My temperature gauge goes to about halfway when it's warm, in either summer or winter. It could be your thermostat. If the thermostat was stuck open it could keep the engine from warming up. Are you still under warranty? If so then I would take it in, it definitely doesn't sound like it's behaving the way that it should.Not sure if it would cause the problems you're having, but you should also check to make sure that the coolant level is ok.For what it's worth, here's a fuzzy pic showing my temperature gauge. Doesn't seem to matter what the outside temp is, the gauge always points to the same place when the engine is warmed up.
Posted: Fri Nov 07, 2003 4:28 am
My heat gets too hot before the engine temp gauge even starts to go up!It rocks the party...
Posted: Fri Nov 07, 2003 2:04 pm
by Altus
Oh yeah -- if it takes any more than 5 minutes to warm up while driving, you definately have a problem. Judging by how long it takes, and the fact that your temp guage is barely moving, I'd say it's a good bet your thermostat has failed in the open position. Get is changed now -- cuz as it gets colder, it's going to get worse. And it's not that good for the engine either, and you'll also start to notice your fuel mileage going down. The engine's designed to run at a certain temperature you see, and there is such a thing as TOO cool.....Dealer under warranty, or a shop of your choice -- but I'd say get it changed out.
Posted: Fri Nov 07, 2003 11:12 pm
by Savoy
It definitely does sound like the thermostat. If it is and you are not under warranty it is very easy and cheap to replace. I wonder how long a thermostat is to go before changing?? Or is there even a maintenance schedule for it? I am right at 60,000 miles and I haven't done any coolant/radiation maintenance .-Savoy-
Posted: Sat Nov 08, 2003 12:25 am
by meathead333
you could also just start your car up early and let it warm up till you get it fixed
Re: Heat and engine question (meathead333)
Posted: Sat Nov 08, 2003 2:51 am
by Frosty Girl
I have been starting my car early and letting it warm up. It still doesn't get very warm though. I'll call Monday and make an appoinment. Thanks for the advice. I've only had my Vibe for about 10 months, so I still have lots of warranty time on it.
Posted: Sat Nov 08, 2003 3:47 am
by millster
Well, glad to see you back here! I agree. Doesn't sound right. I can start my car, let it run for about a minute and by the time I've driven 3 or 4 blocks it's starting to warm up. Hope the dealership is able to straighten it out for you.
Posted: Tue Nov 11, 2003 2:51 am
are you going to take it back to the dealer? let us know what they say/do.
Posted: Fri Nov 21, 2003 8:55 am
FrostyGirl, I know you have other things to worry about since your car got molested, by the Hit and Run, but did you ever get the engine warm up problem looked at?
Re: Heat and engine question (joatmon)
Posted: Sat Nov 22, 2003 5:05 am
by Frosty Girl
I have an appointment next week, so I'll let you know what they find.
Posted: Wed Dec 10, 2003 7:32 am
by Frosty Girl
Well the thermostat is fine, that's what they say atleast. My poor car is cold and still smashed. I'll have to post a picture of it. It's very sad.
Posted: Wed Dec 10, 2003 2:52 pm
by AKLGT
sorry to hear it got smashed. my heater works pretty well and gets the car toasty. i did add a heated seat on the drivers side too so that adds a bit of extra warmth.
Posted: Thu Dec 11, 2003 1:00 am
by Altus
Go to another dealer..... because if your car takes that long to heat up, there's something wrong and they should have found it before you left.What'd they say anyway? Did it heat up normally for them? What tests did they do?
Re: Heat and engine question (Altus)
Posted: Thu Dec 11, 2003 3:28 am
by red
how cold does it get in you area, frostygirl? i know when it is -25* or colder here, the car struggles to get to the half way mark, idling wont help it.....when it gets cold like this, wedge a piece of cardboard between the grilles and the radiator, it seems to help.....no car that i know of will stay warm in extreme cold but they do get so that you dont freeze inside ! you can replace the thermostat but the computers are set to run on certain degrees, could try a 195* thermostat....maybe you have a heater door thats not opening all the way and blocking heated air from coming in??
