Clicking noise when turning steering wheel left
Posted: Fri Aug 30, 2002 4:17 am
by NSimkins
Anyone notice a sort of click (or tick) noise when turning your steering wheel to the left?This seems to only happen to me when I first get in my car and move out of the driveway/parking lot and make my first turn. Usually after the first turn, I can't get the tick noise to recreate.A couple times only it would tick everytime I turn left. This may be due to temperature changes or something.I would take it into the dealer, but more and likely I (or they) could not replicate the problem.I also looked under the dash at the steering mechanics, but could not see anything visible that may cause the problem. Maybe somewhere where the joints swivel when turning?Just wanted to get other opinions.
[Modified by NSimkins, 3:19 PM 8/30/2002]
Re: Clicking noise when turning steering wheel left (NSimkins)
Posted: Sat Aug 31, 2002 1:41 am
by sharky
the only tick i here when going left is when i try to turn the blinker on and it actually sticks, but just like yours it only happens once and usually its the first time you go to use it.It makes me think that is the position where the steering wheel and turn signal stick. you know how the wheel turns back and turns the blinker off.....must be the sweet spot
Re: Clicking noise when turning steering wheel left (sharky)
Posted: Sat Aug 31, 2002 5:03 am
by NSimkins
This happens when I am not using the turn signal. Normally just as I pull out of a parking space or my driveway.But now that you say that about the turn signal, maybe something bumps together during the first turn left... not too sure though. It sounds a little different than the turn signal click.
Posted: Sun Sep 15, 2002 10:52 pm
by MPankau
My bet is that it's your auto headlights turing on, they click. And since you are stating it only occurs when you first get in, the headslights won't auto-on until about 15 seconds after the car has been started. Are you parked in a shady area? (Dark not bad ) Try turning the car on and waiting a minute before making that first left. Good luckMP
Re: Clicking noise when turning steering wheel left (MPankau)
Posted: Mon Sep 16, 2002 12:42 am
by NSimkins
Thanks, but I know for sure it's not the Auto-Headlamps (Twilight Sentinel) and pretty sure it's not the turn signal clicking. Still haven't had the time to get under and check it out.If I figure anything out, I will post it here in case anyone else has the issue.
[Modified by NSimkins, 11:43 AM 9/16/2002]
Re: Clicking noise :1st VIBE we test drove clicked during >
Posted: Mon Sep 16, 2002 4:50 am
by wiener
1.) stop and go driving ( acceleration front standstill )2.) turns to the passenger side ( right turn ? ) Second test drive of 2 other VIBES at same lot : This occurred : 1.) Clicking on acceleration in reverse or drive . 2.) Clicking when putting shift lever from PARK into DRIVE , NEUTRAL , or REVERSE during standstill w/ brake pedal applied So could be related . SEE MY PREVIOUS POST FOR MORE INFO . Hope this helps .Good Luck THESE ARE AUTOMATICS THAT CLICK / CLANK
Re: Clicking noise :1st VIBE we test drove clicked during > (wiener)
Posted: Mon Sep 16, 2002 4:59 am
by NSimkins
Thanks for the post, but the click noise I am hearing is coming from somewhere in the steering column area under the dash. The noise you are referring to was something I did initially experience, but my clanking noise went away after a couple days (as previously stated in other posts on this subject).THIS click noise only happens normally the first time I turn the wheel to the left, about 1/2 of a full turn. Normally I have to leave the vehicle sit for more than an hour to be able to recreate the noise.This particular noise I am referring to in this post has to do with something unrelated to the issue you are having (
http://forums.genvibe.com/zerothread?id=884).EDIT 12/30/03 -- This noise went away a month or so after initially reported.
Re: Clicking noise : Good Luck on this 1 : possibly tierod , balljoint ?
Posted: Mon Sep 16, 2002 12:05 pm
by wiener
Take to dealer and hopefully they'll hear it . Maddening isn't it ? Best of Luck
Posted: Fri Sep 26, 2008 10:14 am
by Paleogirl2003
I have also recently noticed this clicking sound when i back out of my driveway and turn the steering wheel left! I mentioned it to the dealer when I brought it in for service, but they didn't hear it / couldn't recreate it.Has anyone found a resolution / source to this issue?
Posted: Fri Sep 26, 2008 11:59 am
whoa, time warp. I don't know if Nick ever figured it out or not.
Re: (Paleogirl2003)
Posted: Fri Sep 26, 2008 1:43 pm
by NSimkins
Quote, originally posted by Paleogirl2003 »Has anyone found a resolution / source to this issue?Quote, originally posted by joatmon »whoa, time warp. I don't know if Nick ever fogured it out or not. No, I remember this issue going away "on its own" probably about a year after I bought it... so sorry, no actual fix other than time.
Re: (NSimkins)
Posted: Sat Sep 27, 2008 12:33 am
by Paleogirl2003
O well, I guess I will wait it out then, thanks for responding though
Posted: Sat Sep 27, 2008 1:52 am
by ou.grizzly
Could it be the clock spring in the steering?
