Lowering Springs question
Posted: Wed Nov 05, 2003 2:15 am
by blk182@n7
to Anyone who has used the lowering springs, have you noticed an increase in the pogo effect of is the vibe steady ans smooth?
Re: Lowering Springs question (blk182@n7)
Posted: Wed Nov 05, 2003 4:13 am
by Sub-Vibe-R
With the lowering spring, the suspesion is harder. The car roll less while cornering. But it could have difference between the differand bran of spring.
Posted: Thu Nov 06, 2003 4:05 am
by Flip-Side
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. Others I've heard on genvibe say there is a slight bouncing on harsh road, and the stock shocks can only do so much with less travel due to the shorter springs.
Re: Lowering Springs question (Flip-Side)
Posted: Thu Nov 06, 2003 4:14 am
by Sub-Vibe-R
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. Others I've heard on genvibe say there is a slight bouncing on harsh road, and the stock shocks can only do so much with less travel due to the shorter springs. The wheel hop seems to be a little more present since I installed my spring. I don't know if it is only because my driving style has changed or it is related...
Posted: Thu Nov 06, 2003 5:10 am
by HammerHead
quote:have you noticed an increase in the pogo effect of is the vibe steady ans smooth? No matter what springs you use, there is always going to be a forfeit of ride quality on harsher surfaces. It is one of the reasons upgrading your shocks is a good idea when you lower your car. If someone were to upgrade their shocks, what would be the best to get?
Posted: Fri Nov 07, 2003 1:38 am
by QUIKAG
I've never considered the Vibe steady and smooth. It's always been a bit firm. When I added the TRD springs, I noticed a bit firmer ride, but the MAJOR benefit is the MUCH better high-speed stability. Darn car cruises at 90-100mph and feels rock solid.
Re: Lowering Springs question (QUIKAG)
Posted: Fri Nov 07, 2003 1:53 am
by blk182@n7
Well SEMA was just here in Vegas and I missed due to work and med school. but i heard they are presenting new aftermarket parts for the Vibe/Matrix owners....we will just have to see
