2003 Vibe FAQ from GM
Posted: Tue Nov 04, 2003 10:31 am
In the pile of paperwork I got with my 2003 vibe, there was a GM 2003 Vibe FAQ. A number of the topics in the FAQ come up here in the forums. Here it is, in case you lost or never got one.======================================================================================================================Does my Vibe have an air filtration system?Yes, the Vibe does have a pollen/dust filter. If you notice a change in the amount of airflow coming out of the heating and air conditioning outlets you may have a dirty filter. The filter is located inside the heating and air conditioning housing. The filter door is right behind the glove box.See Section 6 of your Owner's ManualWhy doesn't my cigarette lighter or the accessory power outlet inside the center console work when I turn the vehicle off?The power for the lighter and power outlet is turned on whenever the ignition key is placed in the "accessory" or "run" positions. This will help reduce the chance of running the battery downSee Section 2 of your Owner's ManualWhy does the rear lift-glass window washer have two washer positions?When you rotate the rear wiper switch down the rear washer only will operate. By doing this you will prewash the back glass and reduce the possibility of scratching the glass because of dried dirt. When you rotate the switch to the upper washer position the washer and the rear wiper will operate.See Section 2 of your Owner's ManualWhy does my radio display occaisionally go dim during daytime driving (Automatic Light Control)?The Automatic Light Control (ALC) feature in your vehicle may temporarily switch headlamp and interior light systems to the nighttime mode when you pass through darker ambient conditions (under a bridge, overpass, etc.) This system has a built in time delay of approximately 15 seconds after you start your vehicle at night and place the transmission in gear before the system operates. You should refrain from placing objects, or stickers on the windshield at the left lower corner. You will find the light sensor at the left upper corner of the instrument panel.See Section 2 of your Owner's ManualWhy can't I turn the headlights off? Daytime Running Lamps (DRL)This safety feature will turn your headlamps on at a reduced brightness during daylight to make it easier for others to see the front of your vehicle. This can be especially helpful in the short periods after dawn, and before sunset.- The system does not turn on the taillamps, sidemarkers.- The system will not activate if the parking brake is engaged prior to turning the ignition on.See Section 2 of your Owner's ManualThe recirculation button turns off when I turn my CLimate Control mode knob to either "defrost" or "heater/defrost" blend positions. Why?This feature deactivates the recirculation mode to help reduce the chance of fogging on windows and the windshield when it is raining, or when the humidity is high. You are able to override this feature by pressing the recirculate button again.See Section 3 of your Owner's ManualWhat is the LATCH System?Your vehicle has been equipped with the newLower Anchorages and Top Tethers for Children system (LATCH). In order to use the LATCH System, you need a special Child Retraint Seat that has two attaching points at its base and a top tether anchor. LATCH locations are below the LATCH fabric labels on all second row seats. There are two LATCH locations in the second row (both outboard-seating positions). The top strap anchors can be found in a covered compartment on the floor of the rear cargo area. You may have to lift the compartment door to find the anchors because they may have rotated.See Section 1 of your Owner's ManualHow does the Content Theft-Deterrent System (Optional Feature) work?If equipped with Content Theft-Deterrent system, there will be a red indicator light to the left of the steering wheel labelled "Security". There are several ways the system can be activated after the doors are closed, and they are as follows:- Press the LOCK button on the Remote Keyless Entry fob- Press the power door LOCK button to lock all doors- Locking the front doors manually with a keyThe system will automatically set after a 30-second delay. Once the system is activated the red indicator will flash.The alarm will sound the horn intermittently and flash the headlamps, turn signals and interior lights. If any door/hatch is opened forcibly, or the battery is disconnected and then reconnected the alarm will activate.If the rear hatch, or lift glass is opened after the system is activated by using the key, the alarm will soundSee Section 2 of your Owner's ManualI have 215/50ZR tires on my Vibe, will I need to change them to drive in the snow or ice?The P215/50ZR17 size tires are high performance tires. High performance tires are designed for very responsive driving on wet or dry pavement, but they may not offer the traction you would like on snow or ice covered roads. You may also notice more road noise with high performance tires and that they tend to wear faster.See Section 2 of your Owner's ManualHow can I minimize fogging of the windows inside my vehicle when it's raining or when the humidity is high?To help dry the air in your vehicle and to reduce fogging:1. Press the A/C button.2. Turn the mode knob to defrost. Recirculate will turn off; you will want to leave it off so you don;t recycle moist air.3. Turn the fan knob to Hi and adjust the temperature knob to a comfortable setting.See Section 3 of your Owner's ManualHow do I install the rear cargo track tie downs?The eight tie downs and installation diagram can be found in the glove box when the vehicle is delivered.See Section 2 of your Owner's ManualHow does my Remote Keyless Entry (RKE) (optional feature) work?This feature can lock and unlock your doors and lift glass from 3 feet up to 30 feet. At times you may notice a decrease in range. This is normal for any remote keyless entry system. If the transmitter does not work or if you have to stand closer to your vehicle for the transmitter to work, try this:- Check the distance. You may be too far from your vehicle. You may need to stand closer during rainy or snowy weather.- Check your location. Other vehicles or objects may be blocking the signal. Take a few steps to the left or right, hold the transmitter higher when you are pressing the buttons.- Check to determine if your transmitter's battery needs replacement.See Section 2 of your Owner's ManualWhat type of electrical accessories can I use in the 115-volt AC outlet?The 115-volt AC outlet is designed to handle accessories with a two-proing power cord, and a maximum power usage of 1.0 Amp or less.
The system will reset itself after a 30 second delay if an accessory rated higher than 1.0 Amp is used.See Section 2 of your Owner's ManualHow do I get the maximum performance from my air conditioner?On very hot days, open the windows just long enough for the hot air to escape. You should then make sure that you have the RECIRCULATE and A/C buttons depressed, and the air conditioning mode knob placed in the VENT mode.See Section 3 of your Owner's ManualWhy is there a beeping sound inside my vehicle when I shift my manual 6-speed into reverse?This feature is there to alert the customer that he/she has shifted the transaxle into reverse. This audible sound is there to ensure that first gear and reverse are not confused.See Section 2 of your Owner's ManualWhy is there air coming out of the side A/C vents when I have the climate control blower on?Airflow through the side vents is normal in all modes. To optimize the effectiveness of your system in the floor, defog, or defrost modes, close the outboard vents.See Section 3 of your Owner's ManualWhere do I store my flat tire after I install the compact spare tire?Place the flat tire on the rear cargo arear floor panel and secure the tire with the tire tie-down straps located under the cargo floor panel. The proper tie-down strap routing can be found in the Owner's Manual.See Section 5 of your Owner's ManualWhy can't I latch the rear center seat belt?The left rear seat belt buckle and the center eat belt buckle may bemispositioned. Both outboard seat belt latch plates nad buckles are different from the center latch plate and buckle. You can identify the center seat belt buckle by looking for the word "CENTER" on the side of the seat belt buckle.See Section 1 of your Owner's ManualPN22689648Certain restrictions, precautions and safety procedures apply to operating your vehicle. Please read you Owner's Manual for complete instructions. All information contained herein is based on information available at the time of printing and is subject to change without notice 2002.
