Can anyone tell me if the in dash cd changer has RCA hook ups for a subwoofer?
Posted: Tue Aug 27, 2002 10:21 pm
by Triton
I have a JL Audio Poweredge with two 10" subs and an attatched amp that I would like to connect to my in dash stock cd changer. Does anyone know if you can do this? Any help would be appreciated.
[Modified by 8th Planet Vibe GT, 9:24 AM 8/28/2002]
Re: Can anyone tell me if the in dash cd changer has ... (8th Planet Vibe GT)
Posted: Tue Aug 27, 2002 11:18 pm
by DVDvibe
Most stock stereos do not have rca hookups, you will have to buy them unless the vibe is different, even though it does have a built-in amp.
Re: Can anyone tell me if the in dash cd changer has ... (DVDvibe)
Posted: Wed Aug 28, 2002 12:00 am
by yank dini
Might as well buy a new radio for that. Besides it wont sound as good with that factory radio.
Re: Can anyone tell me if the in dash cd changer has ... (yank dini)
Posted: Wed Aug 28, 2002 3:55 am
by DVDvibe
I agree 100%, it would be best to just buy a new head unit and speakers and an amp if I were you 8th planet.
Posted: Wed Aug 28, 2002 10:32 am
by sharky
i say leave the radio in and just add what you have to it, and if later you dont like it then replace it..if you have a nice amp the radio source doesnt matter its the amp that produce the actual sound the radio just gives it signal.
http://forums.genvibe.com/zerothread?id=570
Re: Can anyone tell me if the in dash cd changer has ... (sharky)
Posted: Wed Aug 28, 2002 9:07 pm
by Triton
Thanks for the tips everyone. My goal is to stay with the stock head unit if possible. Like sharky said, the radio just produces the signal, the amp does the work. And I know that the amp can drive those speakers because I had it in my last car. I did have an Eclipse head unit in there but all that offers is more control over the amp and sub without changing the gain on the amp. I think all I will have to do is set the gain right and I should be all set. I have a friend who has set up multiple audio systems in cars and he said it should be no problem. Let me know what you guys think though.
Posted: Wed Aug 28, 2002 9:18 pm
by sharky
i take it your amp most have a built in crossover in it if your just hooking it up to subs? The gain on the amps is messing with the actual watts going to the sub, where a crossover or equalizer can add or remove the highs, mids, lows. With out a crossover or equalizer you could send highs to your sub and that will destroy your speakers.
Posted: Wed Aug 28, 2002 9:42 pm
by Triton
I believe it does. I did not have an EQ in my last car and the sound they put out was great. I will definately check for the crossover when I get home, but my friend said that he remembers seeing a switch on it and I had those subs in my last car for 3 years and they sounded really good and I never had anything happen to them. I am sure that it does have a crossover but I will take a look to confirm that. Thanks sharky!
Posted: Fri Aug 30, 2002 9:52 am
by Triton
Just wanted to let you know that there is a crossover in the amp. Thanks for letting me know so that I could double check.
Posted: Fri Aug 30, 2002 9:37 pm
by sharky
coolI looked at the factory amp yesterday, there are no settings to adjust on it. But im sure if we knew which wires went where you could wire up a better amp. Just need a wire diagram or take all the panels off.
Posted: Sat Aug 31, 2002 10:09 am
by TwIsTeD_ViBe
HeY i didnt know the car had a factory amp!! wheres it at??
Re: Can anyone tell me if the in dash cd changer has ... (TwIsTeD_ViBe)
Posted: Sat Aug 31, 2002 10:13 am
by NSimkins
quote:HeY i didnt know the car had a factory amp!! wheres it at??The amp is only included with the Moon & Tunes package... it includes an "upgraded stereo" with amp and tweeters... and a moonroof.
[Modified by NSimkins, 9:24 PM 8/31/2002]
Re: Can anyone tell me if the in dash cd changer has ... (NSimkins)
Posted: Sat Aug 31, 2002 10:14 am
by sharky
its under the passenger side. and was real easy to take out..only 3 bolts.plenty of room for a bigger amp!!!
Posted: Sat Aug 31, 2002 10:16 am
by NSimkins
quote:its under the passenger side. and was real easy to take out..only 3 boltsNow that I look, there is a box under each seat that almost looks the same in size, etc.. How can you tell the difference?
[Modified by NSimkins, 9:16 PM 8/31/2002]
Posted: Sat Aug 31, 2002 10:30 am
by sharky
HmmmI'll look tomorrow when its day light out. But the one on the passanger side is bigger then the one under the driver side. plus it has the same shape and horizontal aluminum fins like amps.
