Leaking under the glovebox?
Posted: Tue Oct 14, 2003 4:47 am
by XtremeDEW
First off, I am new to this forum and I really took a like to it! I didn't know there was a forum just for the Vibe! That Rocks. But heres my problem:Is anyone else having any problems with water leaking under the glovebox? It seemed to start happening when the weather got cold. Everytime I take a hard left turn a stream of water leaks from under the glovebox. I am just a little worried because the engine control system is right there. I took it to the dealership today, they thought it was the air conditioner and would have it back in a couple of hours but now they want to keep it overnight? Any thoughts or ideas?I miss my Vibe! I want it back!
Re: Leaking under the glovebox? (XtremeDEW)
Posted: Tue Oct 14, 2003 4:55 am
by Hot Vibe
It could be that you have some leaves stuck in the drain fromo the windsheild. They are probably running a water test. Is it water or antifreeze? Is it at NOONAN?? They have excellent service there. I am sure that they will take care of you and the Vibe.
Re: Leaking under the glovebox? (Hot Vibe)
Posted: Tue Oct 14, 2003 6:01 am
by drunkenmaxx
that could have been the water breaking. are you aware or not as to whether your vibe might be pregnant? you may have a baby vibe along the way!
Re: Leaking under the glovebox? (drunkenvibe)
Posted: Tue Oct 14, 2003 7:09 am
by MrRich
Welcome to the forum!They will find the problem,for sure!Oh!And don't listen to drunkenvibe.He is our joke maker,our little cloun!That's why we love him
Re: Leaking under the glovebox? (MrRich)
Posted: Tue Oct 14, 2003 7:40 am
by Vibe Rater
This is probably not a serious problem. Or maybe it is. It sounds like A/C drain tube may be plugged, or maybe it isn't. You may have a water leak somewhere, where the sealer was not properly applied. Or maybe it isn't that either. Does it happen after the A/C has been running continuously for a while, or during and after a good rain or car wash? Your dealer should be able to diagnose and fix this problem, or maybe they won't.
Posted: Tue Oct 14, 2003 9:00 am
by XtremeDEW
Baby Vibe?? WOW! I swear she said she was on the pill. or was that I'm on the pillow?? oh well, more vibe for the buck! HA!
Re: Leaking under the glovebox? (Vibe Rater)
Posted: Tue Oct 14, 2003 9:04 am
by XtremeDEW
Yeah I took it to MORAN in Southfield. They said it was probally the A/C, I haven't had the A/C on in a while though, and I not sure if it rained that much to leak like it was. But only a certified tech will know the real answer. Thanks
Posted: Fri Oct 31, 2003 9:02 am
So, did they fix it? Has the problem come back?
