stb ?
Posted: Fri Oct 10, 2003 5:38 am
by mrgrn
I have gotten a cheap one off of ebay. It has a nut at each end to tighten it up. do i install in and then take all the slack out and make it tight? Also the bolts that hold the round thing at the end habe bolts holding them to the cross piece, should i tighten them as well? What do i have to tak off the top of the towers to install this piece?Thanks In advance
Re: stb ? (mrgrn)
Posted: Fri Oct 10, 2003 7:25 pm
by scherry2
quote:I have gotten a cheap one off of ebay. It has a nut at each end to tighten it up. do i install in and then take all the slack out and make it tight? Also the bolts that hold the round thing at the end habe bolts holding them to the cross piece, should i tighten them as well? What do i have to tak off the top of the towers to install this piece?Thanks In advanceremove the 3 nuts on each strut tower. remove the metal ring. put the strut stabilizer bar on and tighten the nuts to 29 ft lbs. then take the slack out of the bat by tighten in the nut on the bar. hope this helps.i got the same kind of ebay. and I'm happy with it
Re: stb ? (scherry2)
Posted: Sat Oct 11, 2003 9:01 am
by mrgrn
thank you very much
Re: stb ? (mrgrn)
Posted: Sat Oct 11, 2003 12:25 pm
by meathead333
i just got one too! now we can all be alike, yippie!
Re: stb ? (meathead333)
Posted: Sat Oct 11, 2003 1:44 pm
by AKLGT
i have yet to get a stb. undecided. meat, let me know if it makes any difference... have the TRD springs, just not sure on the STB.
Re: stb ? (trdvibe)
Posted: Sat Oct 11, 2003 1:48 pm
by dmitri
go with the rear sways. alot of people get front stb but on our car the rear sways really plant it down.
Re: stb ? (trdvibe)
Posted: Sun Oct 12, 2003 1:44 am
by ArcsVibe
I installed a STB on Friday and felt a difference on the cornering. It just makes the car feel tighter.
Re: stb ? (mrgrn)
Posted: Sun Oct 12, 2003 8:01 pm
by shibaman
Which one did you guys buy? Is it worth the $?
Re: stb ? (shibaman)
Posted: Sun Oct 12, 2003 10:23 pm
by Pablo1669
quote:Which one did you guys buy? Is it worth the $?If I'm not mistaken... the one on Ebay is usually the F1 Motorsports STB. It costs usually between 30-45 bucks (remember, it is Ebay, prices change easily). It works great, I've had mine for a long time now, and I love it. The car feels much tighter in the turns
