Piaa Replacement Bulbs
Posted: Thu Oct 09, 2003 10:33 am
by engine1
I never hear any one mention them! Are they not widely available? Too expensive?
Re: Piaa Replacement Bulbs (engine1)
Posted: Thu Oct 09, 2003 10:41 am
by GT_03
It is because the Silverstar's are the same quailty and half the price. It was my first mod, and i love them.
Re: Piaa Replacement Bulbs (GT_03)
Posted: Thu Oct 09, 2003 10:54 am
by engine1
I don't know if I would put them in the same class as Piaa, but I think anything is better than the standard 60/55 watt OE. Although you can't get a Phillips or GE bulb that puts out more wattage, its just a different gas that produces light in a different spectrum! I have a set of Piaa's in my wifes car, same 135/115 wattage for five years no burnt bulbs yet, not even the cheapest bulbs have ever lasted me that long, that sold me on Piaa!
Posted: Thu Oct 09, 2003 12:16 pm
by MadBill
Actually, if Watts is wat you want, Phillips does have some pretty good stuff, up to 130 in an H4 from: http://www.powerbulbs.com/rallye.htm, ~US$30/pair and free shipping from Old Blighty to boot!If I have any problems with my Silverstars (3rd brand of aftermarket bulbs I've tried) I think I'll switch to them. I've had a pair in my wife's Buick for almost 2 years.
Re: Piaa Replacement Bulbs (MadBill)
Posted: Thu Oct 09, 2003 11:39 pm
by Jahntassa
Yeah, pretty much agree with the "Too much for what you get".. The silverstars are a better deal, and from what i've heard, the Silverstars last a lot longer than the PIAAs..I'd be careful getting bulbs with a higher wattage than the stocks... If you get bulbs with really high wattage, you should change out the stock wiring for something with a relay...
Re: Piaa Replacement Bulbs (Jahntassa)
Posted: Thu Oct 09, 2003 11:50 pm
by MadBill
I also heard of a guy who went to his dealer for warranty on his damaged foglight housings. Turned out they were melted due to the aircraft landing light bulbs he had installed!
Posted: Fri Oct 10, 2003 4:12 am
by engine1
I didn'y know Phillips had the 130's avail. good to know!--------------------------------------------------------------------------------I'd be careful getting bulbs with a higher wattage than the stocks... If you get bulbs with really high wattage, you should change out the stock wiring for something with a relay...--------------------------------------------------------------------------------Piaa bulbs draw the same amount of power as the 65/55 but use a larger filament and different gases to produce more light without over powering the electrical connections. I did put a World Light product in my wifes car 9004 100/80 watts and it did cook the plug for the light, so I learned that you get what you pay for. But I will try the silverstars when the wifes car needs changing!
Posted: Fri Oct 10, 2003 8:03 am
by DopeVibeGT
I run PIAA's in both my Vibe and GA. Wont buy another brand. I have the purplish/blue HID ones in my Vibe, and they look just like the new HID, and just about as bright. I have the Super whites in the GA and they shine better than the silverstars. Plus, they blow out, I get free ones.
Re: Piaa Replacement Bulbs (DopeVibeGT)
Posted: Thu Oct 16, 2003 10:57 am
by Roadpig
Hey DopeVibeGT...I was thinking about getting some Piaa's for my Vibe GT. Do you remember the part# of the bulbs and where you got them from?Thanks!Roadpig
Re: Piaa Replacement Bulbs (Roadpig)
Posted: Fri Oct 17, 2003 12:43 am
by engine1
Piaa Super Plasma GTX p/n 17655 ,very purple on low,white on high Piaa Super Plasma p/n 15560, light purple on low, white on high
Posted: Fri Oct 17, 2003 4:58 am
by DopeVibeGT
quote: Piaa Super Plasma GTX p/n 17655 ,very purple on low,white on high Piaa Super Plasma p/n 15560, light purple on low, white on highYeah, what they said. I have the 15560's that I got at a local speed shop.
Posted: Fri Oct 17, 2003 8:18 am
by Merzbow
so how much do the silver stars cost???
Re: Piaa Replacement Bulbs (Merzbow)
Posted: Sat Oct 18, 2003 3:31 am
by huy397
See here.http://orderxenarc.sylvania.com/orderxe ... 17Directly from Sylvania.Vibe uses 9006 and 9003, for headlight and fogs.... or vice versa,
