Ported My Throttlebody Pictures
Posted: Fri Oct 03, 2003 3:38 pm
by roadrunner-r
Here are some pictures,i used epoxy to smooth out the whole from the PVC. I just put on a Mini K@N fliter on it. AS for performance,it has better throttle responce,and to me it gained some torque between 2500-5000. IT helped topend as well. I also did the Coolant bypass as well. I recomend doning it.
Re: Ported My Throttlebody Pictures (roadrunner-r)
Posted: Fri Oct 03, 2003 3:41 pm
by roadrunner-r
another
Posted: Fri Oct 03, 2003 3:42 pm
by roadrunner-r
I epoxyed this hole.
Posted: Fri Oct 03, 2003 10:09 pm
by goodvibe
Where's the MAF sensor if you have a 3" intake. You really need that. It's about 2 ft away from the throttle body. I think these smart motors will keep running in a default mode but drive ability and power will suffer alot. Worsed case is BOOM. Might be that 1-2 problem your having. GTs have the best throttle responce in stock form but will make more power with intakes.
Re: Ported My Throttlebody Pictures (goodvibe)
Posted: Fri Oct 03, 2003 11:12 pm
by roadrunner-r
The MAF is in its stock place. I just used a 3" rubber cupling,and used that to adapt to the 3" hose. I was gonna go all out and make a one out of PVC pipe. TO me it was pointless to go to a 3" their. Going threw all that trouble. It already 2 3/4 there ant much resirction there.I think the intake has some resirction,But that another project when i rack more miles up.(1500 on the clock)
Posted: Sat Oct 04, 2003 3:44 am
by dmitri
howed u port and polish it? dremel tool?
Re: Ported My Throttlebody Pictures (dmitri)
Posted: Sat Oct 04, 2003 4:53 am
by roadrunner-r
Dermal baby!
Posted: Sat Oct 04, 2003 11:15 am
by dmitri
which bit did u use?did you do it all by hand just looking at it?
Posted: Sat Oct 04, 2003 11:31 am
by roadrunner-r
I used sanding drums and then i used some fine grid sandpaper. It smoothed it (By hand)Oh ya i did everything by looking at it,thats what did to my LS1 and gained 5rwhp on the dyno and 2lbs of torque
Posted: Sun Oct 05, 2003 12:05 am
by dmitri
nice.lol in the works bypassing power steering and a/c. When you take power steering out you might have to strenghthen some parts i think. (not sure but i dont have any PS on my malibu or 68 camaro, its fun )bypassing AC wont give you much power i think unless the AC is on....which in that case it wont work . i think ill do my throttlebody today.
Posted: Sun Oct 05, 2003 5:19 am
by roadrunner-r
What mods do have on your Iroc? I ran one lastnight (auto) from a stop by the end of the 1/4 i had about 1.5 wagons on him. He had a exhaust and K@N. What do Iroc's run in the 1/4 stock?
Posted: Sun Oct 05, 2003 5:26 am
by NovaResource
Most stock 80's IROC's were mid-15 to high 16 sec cars. Most were 305 V8's but there were a few 350 V8's. The 350's were the ones in the 15's while the 305's were the 16 sec cars.
Re: Ported My Throttlebody Pictures (NovaResource)
Posted: Sun Oct 05, 2003 5:42 am
by roadrunner-r
This was a 350 i asked him,hes a friend of mine.
Posted: Sun Oct 05, 2003 7:35 am
by dmitri
u sure nova???my 88 iroc z28 i have intake, headers, exhaust, computer chip, mass air flow sensor, and look at the time i ran.
Posted: Sun Oct 05, 2003 11:28 am
by NovaResource
Really, wow! I didn't know '88 IROCs came STOCK with an aftermarket intake, headers, exhaust, computer chip and mass air flow sensor.Here are just 2 sites that list the mid 15-sec times for late 80's IROC's:http://www.car-videos.com/performance/d ... times.html
Posted: Sun Oct 05, 2003 12:17 pm
by dmitri
lol simple mods go a long way with that car.trying to get rid of it. looking to get 4800
Posted: Sun Oct 05, 2003 9:23 pm
by NovaResource
Yes, a solid V8 only needs simple mods to go fast. An intake and throttle body along with the headers and exhaust help the engine breath better. Remember, the technology in the 80's was nowhere near what he have today. Most cars now have very good flowing intakes and exhausts.
Posted: Mon Oct 06, 2003 12:40 am
by savedbyzero
I wouldn't do anything with PVC. Heats up and releases gasses that could harm your motor. Just a thought...
Re: Ported My Throttlebody Pictures (savedbyzero)
Posted: Mon Oct 06, 2003 2:19 am
by roadrunner-r
What are you talking about
Posted: Wed Oct 08, 2003 6:40 am
by savedbyzero
You were talking about making a piece for the intake out of PVC. I was suggesting that you find a different material to do so. That's what I'm talking about...
Posted: Wed Oct 08, 2003 9:04 am
by MadBill
It's important to consider the properties of any materials you use in a project (a friend of mine once used aluminum for an exhaust pipe -lasted about 5 min. before it melted!), but I think the temperature at which PCV melts/outgases is quite a bit higher than Vibe underhood temperatures (except very close to the exhaust) so it shouldn't be an issue.
Re: Ported My Throttlebody Pictures (MadBill)
Posted: Wed Oct 08, 2003 10:20 am
by roadrunner-r
I was going to use the pvc,but i felt that it wouldnt help that much as i stated. The Maf is 2 3/4,Thats why i didnt use the PVc. I use to own a 2000 GTP. It had a blower,underhood temps were hotter.(vibe) I used a PVC pipe to make my CAI it never melted.
Posted: Thu Oct 09, 2003 5:39 am
by dmitri
u notice any difference with the work u did to the TB?
Posted: Thu Oct 09, 2003 6:36 am
by roadrunner-r
I noticed better throttle response in the lowend. 2500-4500. Also in the topend as well.
Posted: Fri Oct 10, 2003 1:44 am
by savedbyzero
Melting wouldn't be the issue. Gasses released from heating up would be.
Posted: Fri Oct 10, 2003 1:51 am
by MadBill
True, but not much outgasing occurs until the temperature approaches the melting point. Also, being underhood, human exposure is limited (think of exhaust gas, battery acid fumes, etc.)and apart form some very slight potential for deposition on the mass flow sensor, the engine would be immune to same.
Posted: Fri Oct 10, 2003 6:44 am
by dmitri
yea thats why they tell people when they wanna make their own pipes for "tobacco" not to use PVC...lol
