AC compressor or fan assembly? (noise)
takearushfan
Post by takearushfan »
Hi all. My 2006 Vibe has lately been making an obnoxious noise sometimes when the AC is on. It doesn't always do this but it's frequent enough to be irritating. I attached a link to a YouTube video to show you. I read it can be the AC compressor (God help me if that's the case) or possibly the assembly which would be more ideal. Does that seem accurate based on this video? What else might it be? The plastic shroud itself is secure as is the radiator itself, I will say though that the plastic fan blade can be slightly moved back a bit if you try to pull it towards you even slightly. It looks almost like the blade might be knocking on the shroud's plastic. Please take a look and advise. I appreciate it.
The video record recording:
[youtube]https://youtu.be/DKzgCA5-eWQ?is=0ehWlQC7Itei0xfn[/youtube]
Re: AC compressor or fan assembly? (noise)
From that video, it looks like the fan assembly should be replaced. Video is never a good way to identify a noise source. You could try unplugging the power wiring to the fan motor and then run the A/C again. Checking if noise has gone away. As these Vibes get older, it is harder and harder to locate parts. If all else fails, check your car salvage yards for a used replacement fan assembly. You can also try this site to check salvage yards: https://www.partshotlines.com/
