Rear end vibes 🤙🏻
Posted: Mon Oct 05, 2026 11:18 am
by kripakm
Hello!
This is my first post so thank you for reading.
I bought a 2008 Pontiac vibe 5 speed in August and it’s in excellent condition with 116k miles. One thing I noticed on it was the steering was just slightly off and there’s a vibration at highway speeds. I got an alignment and my steering wheel was just a hair off but not bad at all like .04. But the rear end is off a good bit apparently. The driver wheel is pointing inwards .29 and the passenger tire is pointing outwards to the passenger side another like .22
​Also the thrust angle is .26 to the passenger side.
When I got it I noticed maybe some curb rash on the rear end and one the wheel covers was bent up. So it definitely seems like someone may have slid into a curb or a pothole or got hit on the rear axle. I know this is a solid thing and cannot be adjusted. There’s a constant pull to the driver side at like 50 mph and up.
Has anyone else had a similar problem or know the best way to handle this? Idk if I could maybe get 2 come alongs a try to push and pull the wheels more straight or if that’s just a horrible idea.
Any advice is appreciated.
