2004 vibe , water leak=-
Posted: Sat Sep 05, 2026 10:24 am
by jamesmetairie
2004 vibe, about 189,000 miles. windshield replaced 8 years (??) ago. Vibe painted above pin stripe a few months ago. No rust anywhere on the vehicle.Suspect leak origination spot = the black plastic trim that sits in the rain gutter from the top corner of windshield , passenger side . It runs from near windshield to the forward most bracket of the roof rack mount. I noticed after the paint job the black plastic trim was loose at the forward edge near the windshield . I just tired to push it down hoping it would click into place.
Question = is it likely the paint guy popped that trim off during the prep work? If so how was the vehicle built ? Is there some type of clip that black plastic trim snaps into. I,m seeing just a little water on the head liner corner near the plastic pillar forward of the the passenger head .
Thanks for any advice. Jamesmetairie
Re: 2004 vibe , water leak=-
Posted: Sat Sep 05, 2026 4:30 pm
by andrewclaus
This drawing shows how the 2007 Matrix trim is held on with clips. https://www.japan-parts.eu/toyota/us/20 ... e-moulding I don't know how the water seal is made in the gutter between the door panels and the roof, but it's reasonable to assume that age and the recent work broke something.
Posted: Sat Sep 05, 2026 10:59 pm
by jamesmetairie
I,m thinking perhaps the clip is riveted and the water enters around a loose rivet. The act of pulling the trim off of the clip damaged it. Thanks for the diagram.
Posted: Sun Sep 06, 2026 4:19 am
by andrewclaus
Good luck with it. There may be a weld instead of a rivet, or a welded seam corroded.
When I had the windshield replaced on my '07 last year, I saw a lot of corrosion on the frame, but it sealed okay.
I've been thinking about a similar paint job and was looking at that roof trim, and decided not to tackle it.
Posted: Sun Sep 06, 2026 5:29 am
James. I see you're coming up on 20 years on this forum and have probably read pretty much every post. Don't rule out what I went through a few years ago and is explained in this post: viewtopic.php?p=537125&hilit=wet+headliner#p537125
Seeing how your windshield was already replaced at least once, they may have scratched paint in the process, which then could have rusted through to where you're now getting water inside. Good luck!
Posted: Sun Sep 06, 2026 9:50 am
by jamesmetairie
A post from "coppins" from 2016 has my interest. he mentioned perhaps the windshield pillars are hollow and the water builds up. Then later as your drive or a heavy rain happens it overflows and the leak appears. I just tried to message him to see if he ever fixed his leak problem. thanks
Posted: Wed Sep 23, 2026 11:19 am
by jamesmetairie
I,m considering trying to pull the black trim piece. Not any part of the luggage rack. Just the black trim and perhaps 100% silicon along the length where it sits.. I,m also on genvibe Facebook asking Brett Hardy for advice. I appreciate all the advice I received from genvibers thru the years. thanks
Posted: Wed Sep 23, 2026 11:21 am
by jamesmetairie
