Factory Amp wattage
Posted: Fri Sep 26, 2003 7:14 am
by IceCold
Anyone know the wattage from the factory amp?
Re: Factory Amp wattage (silverawd26)
Posted: Fri Sep 26, 2003 7:32 am
by MrRich
quote: I believe it is 200 Watts.It is correct!
Re: Factory Amp wattage (IceCold)
Posted: Fri Sep 26, 2003 10:10 am
by IceCold
so thats 200 watts by 6 channels then...but there is tweeters so maybe is 40x4 (for the speakers) and 20x2 (for the tweeters)...but either way i should get 45-50 watts RMS for my speakers then
Posted: Tue Sep 30, 2003 6:47 am
by Psychobroker
tweeters are not powered by the amp, so I believe it's a 50 x 4 @ 2 ohms. Moving up to 4 ohm speakers will cut it down to approx. 25-30 x 4.
Re: Factory Amp wattage (Psychobroker)
Posted: Tue Sep 30, 2003 7:07 am
by johnsoax
I thought that the tweeters were in parallel with the front speakers. Also, the ohms is a strange one. They aren't four like normal aftermarket car stereos, and I also thought that they were not 2 ohms.
Re: Factory Amp wattage (johnsoax)
Posted: Tue Sep 30, 2003 8:39 am
by Psychobroker
the door speakers are definitely 2 ohms. It's stamped right on their magnets.
Posted: Wed Oct 01, 2003 2:14 am
by johnsoax
OK I stand corrected. But how are the tweeters wired in.
Posted: Wed Oct 01, 2003 3:04 am
by Psychobroker
I think the tweeters are wired directly to the head unit, but I'm not sure. Someone else might be able to help in that respect
Posted: Wed Oct 01, 2003 3:43 am
by Sub-Vibe-R
quote:so thats 200 watts by 6 channels then...but there is tweeters so maybe is 40x4 (for the speakers) and 20x2 (for the tweeters)...but either way i should get 45-50 watts RMS for my speakers thenForget the RMS... This amp is 200w peak. It should be 50x4 and the tweeters are in parrallele with the front doors.
Posted: Wed Oct 01, 2003 4:31 am
by johnsoax
I know that they don't run off of the head unit. There are only 4 speaker outputs on the head unit. so they are either parrelled off before the amp or after the amp. And after would be easier.
