Loaded knuckle replacement for 2010 Vibe?
Posted: Sat Jun 06, 2026 11:42 am
by SeANMcBAY
I have the 2010 1.8 FWD model and I'm wondering if this loaded knuckle will fit? Apparently the shop said mine is starting to roar?
https://www.amazon.com/dp/B083N16LSL?th=1
Thanks. I'd rather just replace the whole thing than worry about pressing bearings and such.
Re: Loaded knuckle replacement for 2010 Vibe?
Posted: Sun Jun 07, 2026 12:45 am
by Kanovibe
Hi
I have replaced hub bearings and no big deal assembling them, at least the bearings can be of a known quality if from Toyota
John
Posted: Sun Jun 07, 2026 3:50 am
by andrewclaus
In my experience, Toyota parts will fit the Vibe. But I question the quality of some non-OEM parts. I regret a couple of instances of going the cheapest way possible.
I've also had a front wheel bearing fail and I replaced the bearing alone. But I found out my local parts store did not have a press large enough for the work and had to go a little farther to a transmission shop. I paid a little more, about $40 I think, and had to wait most of a day. If I have to do the job again, I'll look at replacing the entire knuckle just to save the travel and down time.
Posted: Mon Jul 13, 2026 12:43 pm
by Capt.Vibe
I am having the same dilemma for my 2010 1.8L. How did that part fit? RockAuto does not list any knuckle bearing hub assemblies but has lots of options for the Corolla/Matrix. Should I just order from those? Should be direct fits?
Posted: Tue Jul 14, 2026 3:51 am
by andrewclaus
Engine, exhaust, drivetrain, brakes and suspension are all pure Toyota, according to all I've seen and experienced.
Posted: Tue Jul 14, 2026 5:47 am
by Capt.Vibe
andrewclaus wrote: ↑Tue Jul 14, 2026 3:51 am
Yes exactly but RockAuto does not list any knuckle/hub assemblies for the Vibe and neither do the parts manufacturers list fitment for the Vibe which I find strange. Same with Amazon It's giving me pause for caution.
Example: None of these parts say they fit the Vibe.
https://www.rockauto.com/en/catalog/toy ... mbly,10923
