Loaded knuckle replacement for 2010 Vibe?
SeANMcBAY
Post by SeANMcBAY »
I have the 2010 1.8 FWD model and I'm wondering if this loaded knuckle will fit? Apparently the shop said mine is starting to roar?
https://www.amazon.com/dp/B083N16LSL?th=1
Thanks. I'd rather just replace the whole thing than worry about pressing bearings and such.
Kanovibe
Re: Loaded knuckle replacement for 2010 Vibe?
Post by Kanovibe »
Hi
I have replaced hub bearings and no big deal assembling them, at least the bearings can be of a known quality if from Toyota
John
In my experience, Toyota parts will fit the Vibe. But I question the quality of some non-OEM parts. I regret a couple of instances of going the cheapest way possible.
I've also had a front wheel bearing fail and I replaced the bearing alone. But I found out my local parts store did not have a press large enough for the work and had to go a little farther to a transmission shop. I paid a little more, about $40 I think, and had to wait most of a day. If I have to do the job again, I'll look at replacing the entire knuckle just to save the travel and down time.
