2009 Vibe AWD Rear Diff Fill Plug
Posted: Wed Apr 15, 2026 12:22 pm
by taxman22
I've got myself into quite a pickle. I went to add rear diff fluid and surprise! the fill plug is stripped out.
I'm planning on trying to weld a 10mm allen into the bolt and then break loose, but..... before I do wanted to check with you fine folks if there is any other tricks or how you resolved?
Also just confirm, the fill plug is not reverse threaded. I want to be sure I don't over tighten when i think I'm loosening.
Cheers!
Re: 2009 Vibe AWD Rear Diff Fill Plug
Posted: Fri May 01, 2026 4:45 pm
by vibedrivermatt
Hey. Just wondering. Did you ever get that sorted?. Welding seems like a good option in that situation.
