radiator fan question=-
Posted: Mon Aug 04, 2025 9:14 am
by jamesmetairie
05 base Vibe . about 185,000 miles. In 06/24/radiator fan motor stopped working. My honest mobile mechanic was out of town , so I went to a recommended local shop. They charged me a arm and leg.($400.+) and replaced the entire assembly/housing. Now 08/25 the fan blade is wobling and hitting stuff. The shop will honor the part warranty, but wants almost $200. for labor.
So I bought a auto zone "dorman" assembly (part # 620-546) for $72. and my honest mobile guy will install.
Question = When I searched around Amazon (part # 620-546), etc. they always question if the Vibe is manual transmission. What does that have to do with a fan motor?
Re: radiator fan question=-
Posted: Mon Aug 04, 2025 10:36 am
I don't know why that would make a difference in the fan assembly, unless it is for a fit issue. Auto tranny radiators have a passage for transmission fluid to be pumped through, manual tranny radiators do not. Maybe its something to do with the different radiators, and how the shroud fits to it. I can't see where the tranny difference would need different fan performance, that's all controlled by the computer anyway
edit :
tpollauf's below makes more sense than it being just a fit issue, excellent point that the auto needs more cooling power to cool both the engine and tranny
Posted: Mon Aug 04, 2025 12:30 pm
Similar to what Joatmon mentioned, I believe most vehicles that had transmission choices, did receive a different radiator depending on the transmission. Mainly for capacity of the cooling fluid. With a manual tranny, lets say you only needed 3 qts of coolant (just grabbing some random numbers there) whereas an automatic may require 4 qts. So then possibly a stronger/bigger fan would be needed to cool the fluid for the automatics. Just my guess at this point.
Posted: Mon Aug 04, 2025 9:07 pm
by jamesmetairie
Mobile mechanic installed it today. No problems doing it. AZ stocks dorman and also their duralast. Took a better look at the old one after it was pulled. The shaft was wobbly.
Posted: Tue Aug 05, 2025 4:13 am
by andrewclaus
I just did that replacement a couple of weeks ago, failed motor bearing. Got the whole fan and shroud at the local auto parts store for $80. Maybe I'll need to keep an eye on it.
