Loose wire under alternator connects to what
Posted: Sun Jun 22, 2025 7:29 pm
by KJones
Pulled a wire loose while working on alternator on my 04 Vibe GT. It's a blue wire that was alone in its plastic conduit coming from in the harness that includes the alternator connectors. There looks to be a switch mounted in top of the A/C compressor with a hole that it might have come out of, but I might be looking at a vacuum switch air hole.
Re: Loose wire under alternator connects to what
Posted: Mon Jun 23, 2025 4:38 am
by andrewclaus
If the wire insulation is black with a white stripe (I think I can see the edge of a white stripe), it's power for the magnetic clutch for the A/C compressor. It's easy enough to check--does the A/C work?
Posted: Mon Jun 23, 2025 4:48 am
That's what I thought. Found this pic in another thread
