Can the VIN number tell what options a car was built with?
Posted: Mon Sep 22, 2003 4:35 am
by E-Man
Any one know how much information can be extracted from a VIN number? engine, paint color, interior color, stereo options, wheels, transmission type, etc?
Re: Can the VIN number tell what options a car was built with? (E-Man)
Posted: Mon Sep 22, 2003 4:41 am
by Reynoma
E-Man,Check out the following discussion thread:
http://forums.genvibe.com/zerothread?id=824
Posted: Mon Sep 22, 2003 4:56 am
by NovaResource
quote:Any one know how much information can be extracted from a VIN number? engine,Yes.quote:paint color, interior color, stereo options, wheels, transmission type, etc?No. Those things are coded on the options sticker in the glove box.Basically all a Vibe VIN will tell you is base vs AWD vs GT; if side airbags were ordered and what engine. That's it.
Re: Can the VIN number tell what options a car was built with? (NovaResource)
Posted: Mon Sep 22, 2003 11:00 pm
by Hot Vibe
The numbers inside the glove box are what they call RPO codes.I can give anyone a list of their codes if they wish. I am using those codes to determine how many envy GT's were produced with certain option pakcages.
Re: Can the VIN number tell what options a car was built with? (Hot Vibe)
Posted: Tue Sep 23, 2003 12:12 am
by NovaResource
For those of you who don't know, RPO stands for Regular Production Order. Each option for every GM car has an RPO number associated with it. Each code is 3 digits. For example, codes starting with "L" are used for engines, codes starting with "M" are for transmissions, codes starting with "G" and "F" usually have to do with the suspension, etc.Here are some common RPO codes everyone should know:Z28 = this was the high performance Camaro package. Chevrolet just happened to use the code as the cars name.Z24 = performance CavalierZ26 = this was the Nova SS from 1968 thru 1976, the Nova Rally from 1977 thru 1979 and then the performance Beretta in the 80's.I have a whole list of 1962-79 Nova RPO codes on my Nova webpage:
http://www.novaresource.com/rpo.htm
Posted: Tue Sep 23, 2003 2:14 pm
by threekrows
and with the vin #,some of us can access your rpo codes and tell you what every one of them means,among other things
