No start, battery sparking at positive terminal. UPDATED
Posted: Mon Nov 11, 2024 3:23 pm
I am finishing up a clutch replacement on my stepson's 2003 vibe gt. The engineers are sadists. I have swapped clutches on other vehicles (mostly RWD) in a few hours with no problems.
Anyway, I had my wife try to start it today while I watched underhood and when she turned the key it wouldn't start and the battery positive terminal sparked. No noise from the starter at all. I checked and the starter is getting full battery voltage and a signal from the ignition switch. Battery terminals are clean and I haven't found a bad spot in the cables yet. Normally, I'd just think the starter died, but the sparking at the battery makes me more concerned.
I'll check more stuff soon but had to call it a day. Any ideas are appreciated.
UPDATE: I got it running but now it idles terribly. Random misfires (code P0300). MAF data doesn't seem particularly odd but short term fuel trim is very high, at 20%. So I guess I'll be hunting for a vacuum leak next.
FIXED: The crappy idle was due to a vacuum leak in the EVAP system. I'd already replaced multiple hoses that were getting stiff but built a smoke machine to find the leak. It turned out to be a hairline crack in the vacuum valve on the back of the airbox. I epoxies it, put everything back together and it ran smoother than ever. We brought it back to my stepson last night. That's a 45 mile test drive and he's driving it today. Glad this is over!
