Stuck rear wheels
Posted: Fri Apr 19, 2024 1:29 pm
Hi all, I have a 2006, MT, FWD. Two months ago I backed… pushed… my Vibe into the garage due to a bad clutch. This week I decided to roll it into the driveway to work on, but the rear wheels won’t budge. I put it up on a jack and here is what I noticed. When the parking brake is on, the wheels are totally locked, as they should be with no play or movement. But when I let the parking brake up, the wheel has a little play, as you can move the tire back and forth only about a degree in both the clock and counterclockwise directions with a slight ‘clunck’ sound when it stops. It’s the same type of play and feel on the front tire when you try to spin it and the transmission is engaged, but on the back wheel. It’s a front wheel drive only, and also on both sides. Any ideas and solutions?
Also, because of the bad clutch, there is not enough Oomph to get it to move.
