Strange noise when key moves from Acc to Start
Posted: Tue Jan 02, 2024 4:08 pm
2006 Pontiac Vibe Base model
200k+ miles, no major issues/replacements
Recently went to the store, car was running fine, Came out about 5 min later, and the car had issues starting. NOT the same as you would get with a bad battery (Battery replaced 2 months ago) or a loose cable, it was almost as if it paused briefly when starting.
Drove home, ran fine, parked, turned off fans/radio to try to start it again, and I noticed a sighing/paper bag/gear noise when I moved the key from Acc to the Start position. The noise mimics the temp and gas gages coming up into place, and does the same thing when turning from Start back to Acc with the key. The sound seems like it is coming from below the dash, maybe drivers side kick panel
I tried starting the car and it started, but had the same pause in the starting process.
Video - https://www.youtube.com/shorts/UFwrh4QGalA
I let the car sit for 30 min or so, went back out and tried the key on/off a few times, and the noise was still happening, but when I went to start it, the starter sounded normal and ran normal.
Video (warning: loud beeps) - https://www.youtube.com/shorts/cqSHfzMkPRs
Was the key on/off sound always there, but I did not notice it because of the radio/fans?
If not, what could be making the noise? Could it be the starter?
thanks
-James
thanks
-James
