Recirculation button not working-fix!
Posted: Fri Sep 29, 2023 2:06 pm
So I was reading here that people have had issues with there button not working. I'm guessing it's after the door motor change. If so, do the following.
1. Unplug the motor
2. Move heat and AC controls to heat &vent
3. Move back to AC and make sure the light is on if door is open. (Open means outside is closed off)
4. Plug back in, test button for recirculation. If still not working remove the motor and and plug repeat sets. Then re-install.
1. Unplug the motor
